Old 07-28-2008, 08:42 PM   #1
brawley
Easy Does It
brawley's Avatar
What headers have you used?
Im thinking of getting a set of Hedman headers #69260. Im not sure what is the best for these trucks? short or long? or maybe someone knows of something else out there thats a good buy and fit? thanks
brawley is offline   Reply With Quote
Old 07-28-2008, 10:00 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: What headers have you used?
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-28-2008, 11:43 PM   #3
Hillbilly Deluxe 65
Wheelin' and Dealin'
Hillbilly Deluxe 65's Avatar
my 400 small block has long tubes on it its tight in there but i just like them better im not sure what they are but they are hedmans i know that just not the type
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside
Porterbuilt Extreme front and rear
12bolt w/ eaton tru-trac 4:11 gears
1BADD65
my build thread:
http://67-72chevytrucks.com/vboard/s...=1#post2601700
Hillbilly Deluxe 65 is offline   Reply With Quote
Old 07-28-2008, 11:59 PM   #4
Captainfab
60-66 Nut
The Hedman 69260's are made to fit this era of trucks so there really aren't any fitment issues. These headers are a bit less of a 'tuned' header than the ones for a later model truck such as the '73-'87's. The most common issue with using the later model headers is the clutch bellcrank or z-bar as some call it. If you are running an automatic this is a moot point. Using the later model headers with a manual trans often times requires modifying the bellcrank to clear the header tubes. Board member 64magoo used a set of Hookers on his truck that didn't require modifying. It's a close fit but it works...you can see his HERE
Old 07-29-2008, 12:58 AM   #5
ValveTubeHead
ValveTubeHead's Avatar
I'm using the hooker headers too. I'm not sure if it's possible to install them without removing dipstick tube...but, a heads up to you; I snapped mine flush with the block on the original 283. This prompted me to pull the motor...and pulling the motor prompted installing a crate 350
it all turned out nice. I went to the hardware store and built an adjustable pedal-to-zbar linkage with a couple heim joints and threaded rod. Original linkage was worn severely. Overall, I shortened the effective length of this link by about 1"...the clearance is fairly tight, and shortening this link seemed to help.
...you can follow my journey through link in my sig
Matt
'65 LWB Fleetside
'63 SWB Fleetside
ValveTubeHead is offline   Reply With Quote
Old 07-29-2008, 01:41 AM   #6
hewlett2002000
hewlett2002000's Avatar
thats a beautiful engine setup. looks real nice!!! i want mine to look like that.
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 07-29-2008, 01:42 AM   #7
leftcoast66
leftcoast66's Avatar
Some hooker supercomps I'm runnin right now. Great at stock height, but not sure what I'm gonna do now that I'm gonna lay frame.
leftcoast66 is offline   Reply With Quote
Old 07-29-2008, 02:16 AM   #8
harry
harry's Avatar
got the exhuast shop to do mine that worked out cheaper for me in NZ
harry is offline   Reply With Quote
Old 07-29-2008, 05:20 AM   #9
Frizzle Fry
Frizzle Fry's Avatar
I noticed a couple of BBC's. This thread might be useful for someone here. The framerail/engine clearances are the same (firewall is a bit off) from 60-66 to 67-72 for 2wd trucks. I ended up going with the Patriot Clipsters as can be seen on the 3rd page.
Frizzle Fry is offline   Reply With Quote
Old 07-29-2008, 10:40 PM   #10
brawley
Easy Does It
brawley's Avatar
Hey thanks for the response! I was thinking also of those hooker headers that were posted ,one of you said they had issues with the oil dipstick and plug wires, I have a new set of wires with the straight ends-I also was wondering if there were a big diffrence in performance between short vs long headers -or just using manifolds- there are some pretty cool tru-ram manifolds in the speedway catologe- what do you think? thanks
Old 07-30-2008, 01:46 AM   #11
ValveTubeHead
90degree boots seem to work best with the hookers, as they can be routed without contacting tubes. Shorties are generally more friendly to install and tuck up tailpipes (if truck is ultra slammed)...long tubes usually more performance minded, but honestly ...unless you're routinely tracking it in some headsup fashion...not to worry over. Either header style should be less restrictive than manifolds and offer more bang per buck; manifolds have a cool factor unto themselves though ymmv.
Dipstick tube was my downfall...the stuck bit in the block was essentially fused to it after 44+yrs; access to that area is pathetic while in vehicle... follow the link in my sig to "2008-0209 header fiasco" folder followed immediately by "2008-0216 engine pull" and look for the chewed nubbin stuck in the block
Matt
'65 LWB Fleetside
'63 SWB Fleetside
Old 07-30-2008, 10:09 AM   #12
Joey~AP
TexasBowhunter
Joey~AP's Avatar
VTH,
That motor is sweet!
I just bought a set of ceramic Flowtechs. I have a 77 frame, so my set-up may not be helpful for yall.
Joey~AP is offline   Reply With Quote
Old 07-30-2008, 11:04 AM   #13
Chevy Fleetside
I used some flowtech's on my small block. They fit real well. Also I used corvette spark plug wires so they went behind and under the exaust so you could not see them.. HEI even..
Old 07-30-2008, 01:10 PM   #14
jchav62
1962 C-10
jchav62's Avatar
I'm running the Heddmans on my '62. Fit great... I like the idea of the corvette wires, Fleetside! Looks cool. What brand are they? Do you have a part number? Thanks... Here's a pic of my 327..
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 07-30-2008, 01:51 PM   #15
Anthony Fremont
Anthony Fremont's Avatar
I have these Summit branded Flowtech headers. They fit pretty decently and they're ceramic coated for under $200. Summit wires too:
'66 GMC Custom Fenderside LWB
'90 IROC - L98
'97 1200C Sportster
Anthony Fremont is offline   Reply With Quote
Old 07-30-2008, 04:21 PM   #16
Chevy Fleetside
I have a pair of those summit headers hanging in my garage. I have been thinking of putting them on E bay but if I use the engine they were for I would have to buy a new pair so I am up in the air about it..
Old 07-30-2008, 04:23 PM   #17
Chevy Fleetside
I basically asked for wires for a 75 Corvette with an HEI dist. Oh and a small block..
Old 07-30-2008, 08:51 PM   #18
brawley
Easy Does It
brawley's Avatar
Hey anthony ,those ceramic headers you got from summit are they model # sum-G9006-9? those are the ones I found on the website. you say they fit well? I have a 63' and the guy at summit said they were for a 66' but these have the same frames so I don't see why it would be an issue.Have you had any problems with them? thanks
Old 07-30-2008, 09:35 PM   #19
Anthony Fremont
That be the ones. They aren't hitting anything now that I put the right motor mount perches in. If you want to lay frame, these aren't the headers for you since they hang below the frame. Some people have good luck with Chevelle headers if this is a problem for you.
I haven't driven my truck on the road yet, so I can't comment yet on how well they hold up. The flanges could be thicker, but they aren't exactly thin either. This is with my temporary Thrush glass packs and you can see how they hang down at an angle instead of being parallel to the ground, but I figure an exhaust shop can fix this easily enough when I take it in. I don't have any support hangers on the mufflers yet and they are sagging. This makes it look even worse than it really is.
'90 IROC - L98
'97 1200C Sportster
Old 07-30-2008, 10:16 PM   #20
brawley
Easy Does It
brawley's Avatar
hey thanks for the help! I think im going to order 'em. Do you think these are the same flowtech like advance auto has?
Old 07-30-2008, 10:26 PM   #21
Anthony Fremont
I bought the Summit branded ones. I don't know if the quality is any different than the true Flowtech brand headers.
'90 IROC - L98
'97 1200C Sportster
Old 07-31-2008, 03:18 PM   #22
jchav62
1962 C-10
jchav62's Avatar
Cool! Thanks... I'll do that...
Joseph Chavez
Old 07-31-2008, 05:42 PM   #23
Chevy Fleetside
Get some of those bolt on wire holder tabs so you can bolt them to the block to keep the wires away from the Headers.
Old 07-31-2008, 06:10 PM   #24
64Magoo
I have the taylor bolt downs that hook through the valve covers and they work great!
64Magoo is offline   Reply With Quote
Old 07-31-2008, 08:51 PM   #25
billydonn
Council of the Elders
billydonn's Avatar
Or... Get some Taylor SpiroPro cut-to-fit wires and make your own set... that way you know they will be right.
66 C-10 Stepside
350 Tuned Port Injection
Tremec TKO-600
Truck Pictures: http://community.webshots.com/user/billydonn
Truck Video: http://good-times.webshots.com/video...ost=good-times
billydonn is offline   Reply With Quote
