Old 07-28-2008, 08:49 PM   #1
straitnate14
straitnate14's Avatar
intake gasket
Any one use the little metal heat crossover deals in there intake gaskets? I just lost another intake gasket and I have a spare set but I lost the little metal things. I think the reason They keep going out on me is because I keep using the end gaskets instead of just a bead of RTV they keep the intake to high and push out when you torque the intake down and then start leaking, second time around I just delt with it because it was such a little leak and it only happened when you made a hard turn. Well I just noticed that the little puddle of oil on my intake was bubbling and my vacuum reading was a little lower than normal so I guess it has to be changed now
Oh and it's a weiand 142 blower intake so there is no heat crossover.
ΜΟΛΩΝ ΛΑΒΕ
straitnate14 is offline   Reply With Quote
Old 07-28-2008, 09:14 PM   #2
steelhorse
steelhorse's Avatar
Re: intake gasket
Us a product called (The Right stuff)
by permatex for the end gaskets.It is the best I have seen.
steelhorse is offline   Reply With Quote
Old 07-29-2008, 03:26 PM   #3
70rs/ss
70rs/ss's Avatar
Re: intake gasket
I always use the block off plates, but I live in AZ so i don't need a ton of heat under my carb. Use Ultra copper instead of the end gaskets and it'll never leak.
70rs/ss is offline   Reply With Quote
