Old 07-28-2008, 10:21 PM   #1
andresco50
andresco50's Avatar
Truck didn't start
I installed a new ignition lock yesterday and the truck started without problems, but today she didn't start, I dismounted the steering column and i thought that the ignition switch was damaged, I bought a new one and the truck didn't start, all the fuses are ok, help me guys!!!
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 07-28-2008, 10:28 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Truck didn't start
do you have lights horn? is it possible the battery is dead?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 07-28-2008, 10:42 PM   #3
andresco50
andresco50's Avatar
No, my battery is good, I have lights and it have good voltage.. when the battery is dead or bad you can listen a crack crack sound in the starter, but only the lights goes little down...
2001 silverado 2wd
2003 silverado 4wd
Old 07-28-2008, 11:17 PM   #4
85SBC400
when you turn your key to the on position but not start do you get power to your accs? like the radio, blinkers?......
85SBC400 is offline   Reply With Quote
Old 07-28-2008, 11:33 PM   #5
andresco50
andresco50's Avatar
yes I have accs!! my clutch switch is ok , fuses ok!
2001 silverado 2wd
2003 silverado 4wd
Old 07-28-2008, 11:34 PM   #6
85SBC400
you checked power at the starter? when the key is turned?
Old 07-28-2008, 11:45 PM   #7
andresco50
andresco50's Avatar
That's my last option, do you have a wiring diagram?? to check this?
2001 silverado 2wd
2003 silverado 4wd
Old 07-29-2008, 12:02 AM   #8
impalamark
impalamark's Avatar
Did you put the switch back in correctly
the switch is activated by a metal rod that has to be positioned
correctly to move the switch to the start then run position
I made the mistake of removing mine and fought it a bit
to get everything back together correctly
MArk
impalamark is offline   Reply With Quote
Old 07-29-2008, 12:19 AM   #9
andresco50
andresco50's Avatar
MArk
I turned on the ignition switch with my hands because i taked off from the steering column check the pic!!
2001 silverado 2wd
2003 silverado 4wd
Old 07-29-2008, 12:30 AM   #10
89 crew
If the ignition switch is still off try using a screwdriver to move it. if it works you had it mis-aligned. if it doesn't try jumping the starter. ( big post to small on the solenoid.) If jumping the starter works then the switch or the wires are bad. If it doesn't work remove the starter and have it tested.
89 crew is offline   Reply With Quote
