Old 07-28-2008, 10:24 PM   #1
Old Rust Bucket
Old Rust Bucket's Avatar
Need to trouble shoot rear axle (GM 14 bolt)
Okay it's a 14 bolt 10.25 ring gear in a '76 C20. This problem started a few days after the truck was loaded over capacity. Started out as an occasional rattle and got progressively worse til it would rattle consantly between 30MPH and 50MPH. Then it started making a grinding noise. Got home and checked it, the diff. case was hot enough to fry an egg. I pulled the cover off and the ring and pinnion gears are fine, no shavings in the gear oil. (which was plenty full) No chips on either gear. I went on a hunch and pulled the rear driver's side wheel off. Pulled the axle out. Not sure what I was trying to prove, but when I spun the brake drum just right it would make a a very slight rattle. I'm confused right about now. If it was in the brake drum that does not expalin the diff. case getting hot. unless the oil is moving back and forth transfering the heat. I still wonder if there's a bearing in the diff going out.
Thanks in advance for any help.
Old Rusty Bucket
Rice is for cooking, not for burning......
Past and Present vehicles
'76 C-20
'83 F150
'89 F150
'89 S-10
'97 Sable
Old Rust Bucket is offline   Reply With Quote
Old 07-29-2008, 01:44 AM   #2
leftcoast66
leftcoast66's Avatar
Re: Need to trouble shoot rear axle (GM 14 bolt)
I'd say bearing with it getting hot and all. No resistance when you spin either wheel?
Also did you check how to pinion is to spin, is that bearing fried?
leftcoast66 is offline   Reply With Quote
Old 07-29-2008, 02:53 PM   #3
LONGHAIR
This may sound stupid........but, did you ever reach under there and touch the differential case/cover right after driving before? They get really hot, all of the time.
Ever see an semi truck bob-tailing in the rain?... Steam off of the differential.
LONGHAIR is offline   Reply With Quote
Old 07-29-2008, 04:41 PM   #4
Old Rust Bucket
I know that anytime you gears moving you have friction (I.E. heat) but that diif was just extremely hot.
I begining to realise why $30/hour is money well spent.
The only other idea I got from a different mechanic was the brake drums or the U joints. Well the U joints are tight with no slop and I have not the ambiution to fight with brake drums that have been on there for the last 30 years.
'76 C-20
'83 F150
'89 F150
'89 S-10
'97 Sable
Old 07-30-2008, 12:41 AM   #5
joe231
joe231's Avatar
sound like it could possibly be the axle bearing
CHEVY ONLY
