Old 07-29-2008, 02:05 PM   #1
jimmydean
jimmydean's Avatar
71-72 vs 73+ strong arms and drop spindles
So my old truck being a 6 lug, I decided to get the 6 lug drop spindles to keep things "easy". But this time it's different.
Being a '71, is it easy/logical to get 71-72 drop spindles and associated Strong Arms, or just go the more readily available 73+ and not use the existing brakes? The brakes are ok, but can certainly be swapped out for shinny new ones.
To me it seems logical to go with the more common 73+ for ease of parts. Opinions?
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 07-30-2008, 12:17 AM   #2
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Re: 71-72 vs 73+ strong arms and drop spindles
rotor/caliper should be the same. the only real difference from 71-72 to 73+ is the upper ball joint taper and the size of the u-bolt holding the LCA's to the x-member.
only other thing to watch for is rotors came in different thicknesses but both options were available and interchangable from 71-72 and 73+
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 07-30-2008, 11:21 AM   #3
jimmydean
jimmydean's Avatar
Josh
I was told the spindle on the 71-72 was different and the 73+ rotor wouldn't work. So if I ordered a 73+ drop spindle, I would have to get a 73+ rotor as well, regardless of thickness.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 07-30-2008, 12:12 PM   #4
jimmydean
jimmydean's Avatar
CPP seems to think the spindle they sell supports rotors from 71-87, so it looks like I got bad info. Thanks.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 07-31-2008, 01:04 AM   #5
RunninLo
RunninLo's Avatar
Just for real world info I have a set of 73+ spindles on a project that are running my 72 1 1/4" rotors from my burb project that now sports drilled rotors.
Project is a freinds 66 that I donated the UCA/LCA, and rotors too. Had the 73 plus spindle and he just put the 73+ upper ball joint in my old 72 UCA. bolted it all up slicker than slick.
Josh
88 4x4 crew DD
Old 07-31-2008, 10:27 AM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
1.25" rotors are the same, 71-91. ~81 they introduced a light duty rotor(1") that does not interchange.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
