I like turtles...
Cargo light problem
i am wantin to take out the cargo light in my 79 and fill it and make it smooth. i went to take it out and got confused on the wiring. how is the cargo light and interior light hooked up to the switch by the driver side door? how can i remove the cargo light and keep the interior light hooked up?
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: Cargo light problem
The cargo light and interior light wiring are connected. If you want to eliminate it, just cut the cargo section out of it... You will be left with an orange and white wire..
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
yep,snip them off,be sure to tape up good,should b done.
I like turtles...
sweet, thanks guys
![]() Last edited by jrsmith_2010; 07-30-2008 at 11:03 PM. |
I like turtles...
or i was thinkin maybe a newer 3rd brake light, has anyone done this? is it hard to do?
Still will have to separate the wires, but you will need to tap into the brake switch.
Parts and more parts
I took out my cargo light and made it a brake light with the addition of a 1997 Nissan light fixture. Decently shaped and designed light and it fits over the holes and makes the truck look better.
My 79 has seperate connectors for the dome and cargo light down by the floor below the cargo light switch.
'79' shortbed |
I like turtles...
really? like how are they different conectors when there is only one switch for both?
I"ll post a pic later this evening, my fingers don't explain things well.
'79' shortbed |
Hope this helps. The upper connector on left is the dome light and the lower on right is the cargo light. The wires going off to the right behind the seat belt retractor goes up to the dash.
'79' shortbed |
I like turtles...
sweet, that will be easy to take out, thanks for the posted pictures!
