"THE GREEN GOBLIN"
What are you guys useing for vacum on your trucks with a mild to wild Cam is anyone useing stock power brakes or just sticking to NoN Power! I had an issue with the vacum and my Truck not stopping because of the cam with my stock power brake system! Any suggestions I heard they made some type of electric pump that would make vacum, is there such a thing is anyone useing it if so how does it work? This is just a weekend Warrior but I don't Drive slow maybe race it now and then, so what do you guys recomend I do?
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
![]() Join Date: Jan 2008
Re: Power or Non Power brakes for Mild to Wild Cam
if your worried about not enough vac, you can always add a vac pump driven by your drive belt and also add a vac canister. or you might be able to just add the vac canister. JMHO
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 ![]() http://i195.photobucket.com/albums/z...en58/001-2.jpg |
I have hydro boost on my blazer and my pu, works great
i was running a wild cam in my 87 - i had no brakes - i installed a vac reserve can i got from jegs and it solved the problem - i was not running A/C but it was a simple install and worked like stock - i recommend the can
![]() Join Date: Apr 2008
Jegs or summit should have a small pump to fix this problem.That would be a cheap fix.A hydroboost system will give you the best stopping power but is a more expensive fix/upgrade.
"THE GREEN GOBLIN"
Thanks guys I will look into this, I will check out Summit tonight !
