Old 07-30-2008, 08:59 AM   #1
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
tailgate handle flip
i have a tailgate band off of a blazer without the notch for my truck and im dying to put it on but i think it will be in my best interest to flip the handle first. what kit are you guys using that your happy with? is there a way to make one myself? please let me know and as always pictures on how-tos do help quite a bit.
staggerd86c-10 is offline   Reply With Quote
Old 07-30-2008, 10:19 AM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: tailgate handle flip
78 Build Thread
4Runner Build
Last edited by N2TRUX; 07-30-2008 at 11:05 AM. Reason: Please don't turn this in to a For Sale post.
smashingchuck is offline   Reply With Quote
Old 07-30-2008, 10:56 PM   #3
1984 swb chevy
1984 swb chevy's Avatar
AI used a Sir Michaels kit. It worked out nice. It was easy to do. If you are using a blazer band you wont even have to do any bodywork just weld the filler plate in and grind the welds and touch up the paint.
1984 swb chevy is offline   Reply With Quote
Old 07-31-2008, 12:14 AM   #4
kevinr1970
Originally Posted by staggerd86c-10 View Post
...im dying to put it on but i think it will be in my best interest to flip the handle first.
No man, go ahead and mount the band then shut the tailgate. I am sure you will figure out some way to open it....
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 07-31-2008, 09:54 AM   #5
staggerd86c-10
believe me i have wanted to do it plenty of times i just seem to get back into my right mind, i guess thats why they say patience is a vertue.
1984 swb, why would i have to weld that piece in? the band covers the whole thing doesnt it? the band i have has a small dent and im going to put it for now until i find a good metal worker to take out the small dent it has because i saw how much a new one runs.
Let me know what you think if i have to weld that plate in or not. I turn to you guys whenever i need an answer i always get it here.
Old 07-31-2008, 08:09 PM   #6
OJOE
Crew Cut
OJOE's Avatar
i just did mine and i did weld in the plate. dont know why just did. i also got my band fitted. you do know the blazer band wont just bolt on, you have to take your old tailgate band apart and use the mounting bracket. i had to trim about a 1/4" of the sides of truck bracket to make it fit the blazer band. good luck joe
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 07-31-2008, 10:35 PM   #7
1984 swb chevy
The band will cover the hole in the tailgate. I guess you can get away without welding the filler piece in. I have a mig welder so it was no0thing to weld the filler piece in. If you dont have a mig just run the band without the filler.
