what axels 95 1500
hi all new here and to chevy trucks.can anyone tell me what axles a 95 chevy 1500 4x4 has?do all chevy 1500s have the same axles from the 90s?
Re: what axels 95 1500
Mostly 3.73 and 3.42 gears, depending on the motor. If you have a 4x4, chances are you have a 350 and 3.73 gears...
Mike |
ok well im not talking about the gears im talking about the axles.also do gmc 1500s have the same axle as chevy 1500s?
Windy Corner of a Dirty Street
Most have a 10 bolt 8.5” ring gear while some 1500’s with the increase GVWR option had a 14 bolt semi floating 9.5” ring gear. That later are rather rare.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
The Chevy and GMC rear ends are the same codes.
Mike |
#6 | |
Oil trash and damn proud of it
DirtyLarry, you've worked with GM for awhile right? What's the deal on that? Did the GVW rating constitute the 14 bolt option in half tons? Also, why were some 3/4 tons six lug? Oh yeah, and if you do know those answers, maybe you could tell me what the deal is on the front diffs. I know 3/4 tons up have the 9.25" split case 14bolt IFS front differential, and half tons have the 8.25" split case 10bolt IFS front. But I've heard that the diesel half ton 4WD trucks did and have heard they did not have the 9.25". Which one's right; standard half ton diff, or bigger diff in diesels?
Mark 1997 K1500 Z71, 14 bolt SF 3.73 posi, Bright Blue Metallic. 6" Superlift 1972 C-10, toolbox, p/s, 350/TH350/3.73 open, black int., bronze 2008 Dodge MegaCab. H&S tuned 6.7 Cummins. Fast Four Tons Some of my pics http://s107.photobucket.com/albums/m294/69-350/ Last edited by 69-350; 07-30-2008 at 08:29 PM. |
The 8 lug 9.5” 14 bolt semi-floater was standard equipment in 2500 series trucks with 5.7L engines at that time. The exceptions were 7.4L and 6.5L diesels as both of those came with 14 bolt full-floaters standard. You could opt for a full-floater in a 5.7L 2500 series truck with an extra cost option code of 1TA.
As far as 1500 series trucks went they had the 8.5” 10 bolt semi-floater as standard equipment. There was an extra cost option to increase the GVWR from 6200lbs to 6600lbs under option code F44. The 9.5” 14 bolt semi-floating rear axle and heavier rated rear leaf spring packs were the main ingredients of the F44 package. The F44 package is not part of the Z71 package although both options could be had on the same truck. The 454SS truck in the early 90’s had a 14 bolt semi-floater as standard equipment and I believe 6.5L diesel equipped 1500 series trucks also used the 9.5”. There really isn’t any difference between the 6 lug or 8 lug 9.5” 14 bolt semi-floater other than the axle shaft flanges are drilled differently and brake drums were different. The 9.5” is not all that great of an axle but it is better than an 8.5” and it allows you to run 6 lug wheels if that is your thing. The 6 lug 2500 series trucks of the early 90’s were nothing more than a 1500 with the F44 package. I am not sure why they chose a 2500 designation on those trucks at the time but towards the mid-90’s they started using the 1500 badge instead on the F44’s. Same exact GVWR….different badges. As far as the front diffs go, I am not 100% certain but I believe all 1500 series 4x4’s had the 8.25 front gear regardless of engine.
#8 | |
Also, as for the Z71's, after a certain year (96-up I think?) did they make all Z71's come standard with a limited slip rear end? (and for that matter, with 3.73 gears)? And maybe it's a long shot and not your area of expertise, but I'm told Bright Blue Metallic (my color) is a rare, and 1997 only, paint option. Is that true? I know in 1981 Bright Blue Metallic was offered in Corvettes and sold only on one car, haha. Pointless info, I know. Ah hell, while we're at it, I doubt you know, but why do these 96-up trucks with the fancy rearview mirror, have a slot for the temperature (in the same little screen in the corner of the mirror where the compass resides) but never use the temperature? Was it not offered in the trucks, or maybe only in Cadillacs, or something? I'm sure if I think hard enough, I'll think of some more questions about my truck to test your knowledge, but I'll leave it at that, hah. You do seem to be an expert in this stuff though, with your career being there, and I do like to know little things like that about GM.
Mark 1997 K1500 Z71, 14 bolt SF 3.73 posi, Bright Blue Metallic. 6" Superlift 1972 C-10, toolbox, p/s, 350/TH350/3.73 open, black int., bronze 2008 Dodge MegaCab. H&S tuned 6.7 Cummins. Fast Four Tons Some of my pics http://s107.photobucket.com/albums/m294/69-350/ |
As far as I have ever seen the front diffs in the 1/2 tons are always 8.25s and the 3/4 and 1 ton trucks had the 9.25. The 92 diesel work truck I have has the 8.25 front end in it. Also I know that the frames on the 3/4 and 1 ton trucks are wider than the 1/2 tons, and I believe the mounts are different between the 8.25s and the 9.25s.
As for the paint that color was only offered in 97 and I believe only on the trucks (not SUVs) so there for could be considered rare. The trucks were never offered with a temp in the rearview from 88-98, but share the same mirror as the Tahoe/Yukon/Escalade/Denali which all had the temp option along with the compass.
"I'm the only John Wayne left in this town" John Rich&Kenny Alphin 96 K1500 ![]() 99 K1500 Burb (wife's grocery getter)
#10 | ||||
![]() Quote:
You got me on the mirror deal….I am not sure what the story is with that. ![]() It was fun working with the trucks right out of college as I have been a truck nut since I was a little kid. I was there for the launch of the 1999 GMT800 Silverado which started behind the scenes in 1997. That was an exciting time then I moved into (and out of MI…yayyy!) to the field as a service rep in late 1999 and now work with bigger trucks on the commercial side of the business, which was spun off of GM although we still use GM Powertrain as our engine and trans supplier. My division manufacturers stripped chassis for the RV and Step-Van market if you can guess which company that is. You can touch and taste our products and would swear they were GM but we haven’t been related in 9 years. Another hint is we were just recently aquired 3 years ago by truck and engine company that supplies diesel engines to Phord.
While we have a resident mirror expert online, why doesn't mine work? What can I look for that might be a problem. Sorry, it's probably something obvious, but you never know. thanks
'97 Chevy z71 starline westerner conversion partially removed. |
#12 | ||
So basically, there's at least 6 more trucks in my same color somewhere? Beautiful color you used, too, looks very nice. Knew about the Z71 package, and it overrides the tire size, shoulda known it wouldnt override anything else though. You are a big box of knowledge DirtyLarry, thanks. I'm sure I'll think of something else, too. P.S. do the 2WD and 4WD 14 bolt 9.5" axles vary in width? I don't see why, but I've heard they do. That person full of it?
#13 |
I know that they vary in spring mounting pad width. Not sure about overall axle width. That being said the proof is real easy, just measure your buddys, then yours. WMS to WMS on both would be what is needed because I know for sure the 2wd spring mounting surfaces are narrower than a 4wd. I just bought a 14 bolt semi-float at the wrecking yard for my 1993 K1500 Suburban. My 10 bolt is not worth putting any money into it after 210,000 miles! Got it out of a Z71 with GT4 gears and a G80.
#14 |
The temp sensor works off a sensor that is mounted down in the cowl, or maybe off of a sensor mounted right on the windshield behind the mirror. My old 98 Yukon SLT had a temp/compass mirror in it, but I never had it apart, but Dirty Larry might know for sure. I know the temp sensor was an option on the LS and SLE Tahoes and Yukons and were standard on the high end LT, SLT, Denali and Escalades. And I have seen a few 88-98 trucks with an overhead and center console out of the Denali/Escalade and they look too sweet!
#15 |
Which part is not working, the compass, the temp or the electroluminesant (auto dimmer)?
#16 |
It has the manual dimmer tab, if you know what I mean. But no displays are working. It has two map lights on the bottom, one of them works.
| Bookmarks |
