Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-30-2008, 01:23 PM   #1
blkboot
stall
i have a TCI stall that i bought from a guy awhile ago.at the time i didnt know it was a nos stall.but its a 3000to3500 stall.will it hurt me if im not running nos yet?
blkboot is offline   Reply With Quote
Old 07-30-2008, 02:09 PM   #2
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: stall
Will be just fine. Probably just has anti-ballooning plates for use on the bottle, won't hurt a thing n/a. It will stall at a lower rpm without the spray though......I'm sure you already knew that.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 07-30-2008, 03:38 PM   #3
regan wilson
regan wilson's Avatar
Re: stall
If it doesnt work they can always change it for you . What size is it and how much power do you make . Stall speed doesnt have anything to do with the % of slippage on the top end . It could keep your motor lugged down too hard . You could call TCI if you want to change it and see how nuch they would charge . You could also send it to Kenny Ford at PTC . A stall change usually will cost 200 dollars .
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 07-30-2008, 04:37 PM   #4
Rodms
Rodms's Avatar
Re: stall
Kenny is a super nice guy but you need to know your engine specs and weight and he'll fix you up.Took the tci out 11/2 weeks ago and new ptc installed makes a big difference!!
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 07-30-2008, 05:04 PM   #5
regan wilson
Re: stall
Kenny aint scared to work on a TCI either . I have a $2000.00 Coan converter on the floor now (that I couldnt afford). My trusty old PTC 9" has been in the truck since after Pinks .
Old 07-30-2008, 10:08 PM   #6
djracer
djracer's Avatar
Re: stall
I run a Ptc modified convertor also.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-30-2008, 10:41 PM   #7
Rodms
Rodms's Avatar
Re: stall
Heh guys Kenny is who built the TCI's when they were good,all the people that was any good left when they sold out,I live 15 miles from BTE which is Bill Taylor of T 40 miles from Coleman which is C Incorperated Bte is picking up a lot of buisness and rightfully so Bill also owned Lakeland international speedway just out of Memphis Kenny started with Tci and Tci is now Comp Cams mass production,I think I'm going to try a Bullet cam because Buddy the master grinder from the old Lunati is the man in charge now and its 2 miles down the road
Built chevy tuff!
Old 07-31-2008, 10:34 AM   #8
regan wilson
Re: stall
The best cam I have had was a Bullet . I just pulled my Comp Cam out during my freshen up I will be changing to a new Bullet .
