Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-30-2008, 07:03 PM   #1
Inthuwind
Straight jacket required
Inthuwind's Avatar
What carb?
I've got a 450HP 396BBC, what would be a good carb for this? I thought maybe a quadrajet, but don't know the minimum size. I would like a good street carb with electric choke and something I don't have to adjust alot. Thanks in advance for any tips. What are ya'll using-name brand, part numbers, etc would help.
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 07-30-2008, 08:16 PM   #2
57sailplane
57sailplane's Avatar
Re: What carb?
peak rpm of the cam or point of shift will help alot..
57sailplane is offline   Reply With Quote
Old 07-30-2008, 08:26 PM   #3
Inthuwind
Inthuwind's Avatar
Re: What carb?
1600-5800rpm
Old 07-30-2008, 08:28 PM   #4
Inthuwind
Inthuwind's Avatar
Re: What carb?
http://www.compcams.com/Cam_Specs/Ca...?csid=395&sb=2
Old 07-30-2008, 10:50 PM   #5
Rodms
Rodms's Avatar
Re: What carb?
street only?
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 07-31-2008, 07:28 AM   #6
Inthuwind
Inthuwind's Avatar
Re: What carb?
I have enough for both street and strip, maybe I'll go with the Edelbrock AVS 800.
Old 07-31-2008, 01:10 PM   #7
Rodms
Rodms's Avatar
Re: What carb?
You could go with a quad but electric chokes all hell if they are'nt right and thats all of them ,Why not just put a manual choke on it,you could put it under the dash where you can't see it if you wanted to,but to get your power out of it its a 4 corner carb that has to be worked on a little,BG demon, Holley
Built chevy tuff!
Old 07-31-2008, 01:34 PM   #8
djracer
djracer's Avatar
Re: What carb?
I like a 650 double pumper for street strip applications.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-31-2008, 01:51 PM   #9
Rodms
Rodms's Avatar
Re: What carb?
Yeah that should be plenty his cam specs were real streetable,but its still gonna like the pumps,I think they said stock converter which I would not do just to keep it from loading up in traffic!
Built chevy tuff!
Old 07-31-2008, 02:02 PM   #10
Inthuwind
Inthuwind's Avatar
Re: What carb?
I've got a 2800-3200 stall in a HD th400. So a 650 double pumper is plenty??? I thought I would have to go larger.
Old 07-31-2008, 02:03 PM   #11
Inthuwind
Inthuwind's Avatar
Re: What carb?
Mind you, I have head a little head work done(cast) and the crank shaved .010~~ 1.71 roller tip rockers, Edelbrock RPM air gap intake and .30 over on the 396(402)
Old 07-31-2008, 02:51 PM   #12
Rodms
Rodms's Avatar
Re: What carb?
You should be,but you have to tune them a little but you can jet it up as you need.You could call holley to see what cfm they recomend you also need to figure your VE percent out
Built chevy tuff!
