Old 07-30-2008, 07:19 PM   #1
gottwake
gottwake's Avatar
What's up with my tie-rod hitting the arm?
I dropped the crossmember 1", so do I have to raise and /or move my power steering pump up or back? Thanks
Also, I know I need a different pitman arm, it came with the pump.
Blazer Project
gottwake is offline   Reply With Quote
Old 07-30-2008, 07:31 PM   #2
gottwake
gottwake's Avatar
Re: What's up with my tie-rod hitting the arm?
Sorry, here is a pic.
Blazer Project
Old 08-01-2008, 04:56 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Are you saying you sectioned the crossmember?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-01-2008, 05:14 PM   #4
gottwake
gottwake's Avatar
yes, 1 inch.
Blazer Project
Old 08-01-2008, 11:36 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
I have strong arms but the only issues I had was a little clearance issue with the tie rod hitting the crossmember and the front u-bolt..
MEMBER #6377
Project "7DEUCE"
Old 08-02-2008, 12:30 AM   #6
gottwake
gottwake's Avatar
do you have any pictures?
Blazer Project
Old 08-02-2008, 02:33 AM   #7
FRENCHBLUE72
PROJECT 7DEUCE
You can see where I ground down the bolt and the front of the crossmember. I am not too worried about the crossmember but I do need to fix the u-bolt... Just break out your grinder and make everything fit..
MEMBER #6377
Project "7DEUCE"
Old 08-02-2008, 09:23 AM   #8
gottwake
gottwake's Avatar
well done. Did you raise the power steering pump?
Blazer Project
Old 08-02-2008, 07:15 PM   #9
FRENCHBLUE72
PROJECT 7DEUCE
Nope did not raise the pump or the box...
MEMBER #6377
Project "7DEUCE"
Old 08-03-2008, 08:14 AM   #10
LONGHAIR
What would raising the pump do?
LONGHAIR is offline   Reply With Quote
Old 08-03-2008, 12:15 PM   #11
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
to keep all the geometry correct you should raise the steering as much as you raised the cross member. If you don' it will bump steer.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 08-03-2008, 12:15 PM   #12
bagged74
its just $$$$$
bagged74's Avatar
I think he means the box.
It looks like you need to replace that Pitman arm before you start clearancing everything else.
bagged74 is offline   Reply With Quote
