Old 11-13-2002, 12:48 PM   #1
Zumo
Hot Rods For Life
Zumo's Avatar
Horn troubles.......
How many pieces are there behind the horn button before you take the wheel off? I have a thin medal disc with 3 holes, a plastic ring with 3 holes and the metal cup with a rubber o ring on it. Is that all. I can't get it to ground right to get the horn to work.
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 11-13-2002, 02:28 PM   #2
JimKshortstep4x4
Smile
I think that you have all of the parts needed. Have you tested the hornbrush connection by grounding the brush to a ground?
The metal diaphragm is usually what loses conductivity where it contacts the steering wheel, so if you clean those areas that usually works.
Jim
Old 11-13-2002, 02:43 PM   #3
Erl
Erl's Avatar
There is another piece under the thin metal disk. A type of grounding plunger. Look at the LMC catalog, they show and sell the part.
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 11-13-2002, 03:26 PM   #4
70c10
67-72 Addict!
70c10's Avatar
This is all I have. I think I need those extra parts for my Grant to work.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-13-2002, 03:49 PM   #5
Zumo
Hot Rods For Life
Zumo's Avatar
It's before that, it with the wheel still on.
I guess I have all the parts and I put them in how it's shown in the LMC catalog but I can't get them to stay put. I can ground it out and the horn will work If I touch that button/plunger part with a screw driver and then touch the center stud just fine. I just can get the pieces to stay in and work right. I'll get some pics of it this evening.
Andy
Old 11-13-2002, 03:58 PM   #6
70c10
67-72 Addict!
70c10's Avatar
Zumo,
did you put the pieces back in the right order?. Also I think the metal disc has to have tension. I'm guessing on this. My horn doesn't work either.
Jim
Old 11-13-2002, 04:08 PM   #7
Zumo
Hot Rods For Life
Zumo's Avatar
Zumo,
That's what I am unsure of. They weren't in there right to begin with. The rubber o ring is cracked all to hell. I was going to order that.
Here's the order:
-Plasic piece - Flat side down, screwed in with three screws
-Metal Disc
-Metal cup with rubber o ring(this goes over the 3 screws freely, is that correct? or should the 3 screws supposed to hold that down too?)
Andy
Old 11-13-2002, 04:12 PM   #8
70c10
67-72 Addict!
70c10's Avatar
I THINK THE SCREWS HOLD THAT DOWN TOO. I'M NOT 100%SURE.
Jim
Old 11-13-2002, 04:21 PM   #9
Zumo
Hot Rods For Life
Zumo's Avatar
That how it looks in the LMC catalog but mine aren't doing that. I can pull the cup right out. I think I need to visit a junkyard to see If I can find the right pieces before I order.
Andy
Old 11-14-2002, 11:12 AM   #10
slam33
slam33's Avatar
I had the grant for a while, I remember you need to grind down the plunger. It worked for a while then quit on me. I tossed it and went for the 68 Corvette wheel instead.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 11-14-2002, 11:41 AM   #11
Zumo
Hot Rods For Life
Zumo's Avatar
Yeah I bought a grant wheel and the instal kit but I still couldn't get it to work. I took it back and got my money back.
Andy
