Electric fan-- how did you attach it?
I am planning to install an electric fan. Planning is the key word.
I am going with a Lincoln single or a Taurus twin fan. Both cover the radiator fairly well, but I am not sure how I am going to attach it. Any suggestions? Or better yet, pictures?
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Re: Electric fan-- how did you attach it?
Keep in mind that those Ford fans draw a lot of amps. Make sure your alternator can handle it.
1997 GMC Sierra Ext 1965 Mustang |
I had installed a twin fan off a nissian out of the bone yard (Pull-a-Part) and installed in my 72. I think it cost me 15.00 - 20.00
I had no intentions of doing the swap at that time but a buddy of mine pulled the rad out of it for his ride so I nabbed it anyway. I got lucky and it lined right up with no modifications but I went ahead and trimmed the lip off the fan assembly using a dremmel tool to get closer to the rad with ample clearance. I used long zip ties to fasten the top and bottom threw the vents to test run and verify it will be sufficient. I planed on redoing the attachments by using inserts you can pickup from your local auto parts store. Not sure what they call them or the price. That was 2 years ago and I'm still running zip ties and no problems but I would highly recommend using the aftermarket fasteners after you are sure you have proper cooling. |
Old member
Once you have it in place go to Lowes or Home Depoe and buy the metal braceing stuff they have cut into small 3' sections and make a frame mount for it and hard mount it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Oct 2005
Aluminum shroud is pretty easy to build.....these are twin fans from a Merc Sable. I have a 100 amp alt and there are no probs at all.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Old member
SactoJim,
that is a very nice setup you have there. I like that!!! ![]()
No, my alt will not handle it at all. But that is part of the "planning."
Alt-- plan-- CS 100+amp -- adapter wire with resistor Control --plan-- O'Rilley fan control maybe -- toggle ? -- idiot light for fan? Fan-- Lincoln or Taurus-- have --Yes they do indeed pull the amps. They also really move the air! Mounting--plan-- ?? SactoJim's look really nice. Does the sheet metal just slide into the factory clips at the bottom? Where is the top attached?
100 amp will do it
Loving the Jimmster
Sacto, do you have any pics of the shroud before you installed!! that is great, i would like to take some pics to my metal guy and have him recreate that for me.
Thanks vance |
Parts and more parts
The 100 amp will cover it, UNTIL you are in the city, at a stop light, with the stereo on, the headlights on, and the fans kick themselves on. Now is when you are going to find out if you have the alternator to handle your load.
The reason, I gave you this scenario, is because a standard 100 amp alternator will deliver about 30 to 35 amps at idle on an engine and at a stoplight the tranny engaged (auto tranny) the idle speed will be around 600 RPMs. If you have a stereo system that has any amps, then the load is higher and if you choose to run the A/C, that adds another 25 amps to the load. If you have dual fans and they both start at the same time, there is a significant load change at one time. Now you might see the picture I am trying to paint. Look at a company called Tuff Stuff for alternators that carry around 80 amps at the idle speed and do the upgrade to a 140 amp alternator and never ever worry again. I have purchased a couple from them directly and they are a good company to deal with. |
![]() Join Date: May 2006
Anyone know what cfm's these fans are pulling. I would use a 8gauge wire to feed the fans and have a relay that would handle that load, plus a controller
Nice shroud SactoJim
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-01-2008 at 04:37 PM. |
Nice shroud!
#13 |
I made the shroud and mounted it to the lower portion of the rad support. There's two holes down there that with some shims(washers) worked pretty good. As for the top, I purchased a top cover on ebay and mounted the shroud to it. One of my customers who's forklifts I repair, makes foam sheeting. Sticky on one side. Used it to fill the gaps. Bought the thermostat and fans on ebay also. Don't have cfm specs with me, they're out in the garage. Looks good so far. Can't wait to finish the truck to see what I'll have to change/improve. Here's a couple of pics. Hope this helps?
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
#14 | |
I have a Spal controller on mine that ramps up the 1st fan as temp increases and then at a predetermined temp the other fan kicks on high. I've got quite a bit of miles in stop and go traffic with everthing on including my sound system and haven't had any problems. I completely rewired the entire truck during restoration and that may help some in comparison to a 35 year old wiring harness......but it's not a bad idea to get as high amp alternator as you can.
#15 | |
![]() Last edited by piecesparts; 08-02-2008 at 09:59 AM. |
#16 |
Any info on obtaining parts...controller, relays?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#17 |
Firefighter
Wasn't there someone on here that used a fan from a Jeep and it fit in the stock 67-72 fan shroud, with little modification??
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
#18 |
Trucks N Tranzams
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
#19 |
I have purchased 3 Spal fan sets inthe last few years. the first was from "Be Cool" radiators. Iran into their guys on theHot Rod Power Tour and they set me up with a radiator and fan set for my 84 stroker truck motor. They gave me the fans if I purchased their radiator. The other two sets I purchased through Summit Racing under the "Be Cool" name in their catalog. The fan controllers that I am using and also going to install is the SPAL PWM fan controller and then IT is backed up by the extra relay set that SPAL sell for the second fan. I got mine through Summit racing under the "Be Cool" name, also. These fan controllers and relays are also on the internet under E-bay and other outlets. |
#20 |
Thanks for the help
