Old 07-31-2008, 04:06 PM   #1
dammitmitchell
the pollock
dammitmitchell's Avatar
dont laugh im having issues
ok so i believe ive totally pulled what is known as an brain fart..
be it the beer, lack of shop time lately, or being in a house full of women (wife n daughters mother-in-law etc..etc)
i have this question..
3.73:1 is a "high gear" for a ring and pinion right?>
meanwhile
4.56:1 is low correct??
i was going to order new gears for my truck, and i poulled a brainfart
so the closer i get to a 1:1 ration the "higher the gear" right?
ugggh help me please im soo dumb today
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 07-31-2008, 04:10 PM   #2
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
Re: dont laugh im having issues
Hi Ratio = Low number 2.73 to 1
Low Ratio = High Number 4.56 to 1
That's OK I get the farts everyday
Have a good one, Terry
77 350 Shorty Wide is offline   Reply With Quote
Old 07-31-2008, 04:38 PM   #3
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I always think, the higher the number the lower the gear !!
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-31-2008, 04:48 PM   #4
wicked_sky_gazer
Living Legend
wicked_sky_gazer's Avatar
Ok im not brain fartin i just dont know for sure.... what are the ratio ranges better uses, such as highway, drags, towing... ect?
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia..
project is temporarily on pause again... Thankyou wonderfull economy.. check it out
Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap
East Ok meet East Ok date
Tony
wicked_sky_gazer is offline   Reply With Quote
Old 07-31-2008, 06:37 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
It really depends on the application. My experience has been that 3.08 is good for fuel mileage, but lacks in low end grunt. A 3.42 is a really good all purpose gear that gets decent mileage and pulls well down low. You give up at least one mpg with a 3.73 but it pulls great down low and gives lots of torque through out the power band.
This is based on 2wd SBC equipped trucks that I have owned.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-31-2008, 06:54 PM   #6
68Timber
I know the pieces fit
68Timber's Avatar
I've been playing around with a tire/gear/tranny/rpm/mph calculator and 4.10's look ideal with a 700R4 and 28" tire...
Old 07-31-2008, 10:17 PM   #7
slugish
Slugish
weekend drag machine go with 4.10 / otherwise go wit h 3.73-- the perfect gear for both street & strip with a 700 r4
slugish is offline   Reply With Quote
Old 08-01-2008, 01:01 PM   #8
dammitmitchell
the pollock
i have an 83 with 6in of lift
37's
and a 350attached to 4speed w granny low..
maby i should ask in the 4x4 forums...
hmmmm
i suck at this sometimes im just soooo stumped i wasfiguring i'll lift my truck off teh gorund next week rotate the tires to guesstimate my gear ratio and move a noticible amount towards the "lower number"
i need a tach bad, but to be honest i rapped out my motor the other day FullOpen throttle and only got to 47 MPH in third gear from a dead stop...
that sucks.. but hell the truck can tow a house no problem
but first gear is utterly useless..
Army vet 02-08
Old 08-01-2008, 01:32 PM   #9
tobiahr
tobiahr's Avatar
are you sure the transfer case isn't in low range? you should be going alot faster than 47 in 3rd gear, granny gear or not. even with 4.10 rear you would be going faster than that
tobiahr is offline   Reply With Quote
Old 08-01-2008, 01:42 PM   #10
Rodms
Rodms's Avatar
you can take your rear housing cover off and count the gears on the ring as you spin it around write down, then spin again and count gears on pinion gear write down,divide the pinion into the ring and theres your answer,Just mark the gears with something where you start counting so to count correct ,even if you'll just be out 10 bucks for gasket and lube
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 08-01-2008, 01:43 PM   #11
piecesparts
Parts and more parts
piecesparts's Avatar
I swapped my 84 from a 3.42 to a 3.73 and gained low end pull and in the end stayed the same on mileage, due to putting the engine in the power band properly.
piecesparts is offline   Reply With Quote
Old 08-01-2008, 02:04 PM   #12
dammitmitchell
the pollock
t case was in 2w high.. that definatley works the 4wd is awsome but i took the axes from a buddy's 84 diesel 4x4....
so im not sure y know.. it'll cruise at 60 no problem.. it jsut takes a minute to get there..
and the 47 was me trying to see how fast my truck can get up and go...
blah!
but it cruises fine i usually roll around town in third (40-45)...
Army vet 02-08
Old 08-01-2008, 02:07 PM   #13
tobiahr
tobiahr's Avatar
ok here is a way to get in the ball park on the rear end and tranny...4th gear (counting the granny as first) should be 1 to 1 ratio
http://www.bgsoflex.com/rpmmph.html
