Old 07-31-2008, 04:45 PM   #1
andresco50
andresco50's Avatar
Unhappy Temp gauge problems!
I checked the haynes's gauges wiring system, everything is ok, green (from the temp sensor), pink +, black - ??..... but the needle donīt move from C , the temp sensor is new!
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 07-31-2008, 06:06 PM   #2
Prong
Re: Temp gauge problems!
Ground the lead to the sensor and turn they key on. If the gauge is good (and the wire has continuity), the gauge should peg to Hot.
Prong is offline   Reply With Quote
Old 07-31-2008, 06:48 PM   #3
andresco50
andresco50's Avatar
I'll test that thanks
2001 silverado 2wd
2003 silverado 4wd
Old 07-31-2008, 07:33 PM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Did you put it together with teflon tape? It isn't supposed to have any. It needs to ground to the block.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 08-01-2008, 02:43 AM   #5
andresco50
andresco50's Avatar
Slonaker
Yes a lot of teflon tape... but I checked the ground in the sensor.. it has good ground!!
2001 silverado 2wd
2003 silverado 4wd
