Old 07-31-2008, 06:34 PM   #1
gefs55
Alternator question
I replaced my 1972 truck alternator with a 100 amp summit alternator and replaced the voltage regulator with a stock NAPA regulator. When there is a load placed on the alternator- lights, fan motors etc. it does not appear to be charging. Is there a way to check the output of the alternator before the regulator then after the regulator? Can this be done with a volt meter?
Thanks for any help you can give me
gefs55 is offline   Reply With Quote
Old 08-01-2008, 05:29 AM   #2
JimKshortstep4x4
Re: Alternator question
You can use your volt meter to check the alternator. Reading should be in the 14-15 volt range. An easy check is to measure the voltage at the battery.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
