Old 07-31-2008, 07:46 PM   #1
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Is a 1st Gen Steering box same as a 2nd gen?
I have a few of the 73 up style 4x4 steering boxes and I am wondering if they bolt on the same as the 67-72's. Has anyone tried this? Thanks Ryan.
Dieselwrencher is offline   Reply With Quote
Old 07-31-2008, 08:23 PM   #2
FormerMember
Re: Is a 1st Gen Steering box same as a 2nd gen?
Yep, many times over.
Right now, I have a 97 box on my 68 Frame.
FormerMember is offline   Reply With Quote
Old 07-31-2008, 08:58 PM   #3
Dieselwrencher
Wow. No kidding. That is pretty cool. Did you just reposition the pitman arm to use on the 68?
Old 07-31-2008, 09:22 PM   #4
FormerMember
No, I used a 2WD box with a Jeep pitman arm to go cross over tseering.
4wd is a push pull (front to back) set up. 2WD is side to side.
The only difference is the sector shaft and they interchange betwixt boxes.
Old 08-01-2008, 07:31 AM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
Watch your line fittings. They change to the o-ring style at some point.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-01-2008, 08:08 AM   #6
FormerMember
1981 from flare to o-ring
Old 08-02-2008, 07:49 AM   #7
hgs_notes
GEARHEAD
hgs_notes's Avatar
Is the newer steering box a different ratio?
hgs_notes is offline   Reply With Quote
Old 08-02-2008, 08:32 AM   #8
FormerMember
The 97 I put on is a fast ratio, with supposed variable effort...
Old 08-26-2008, 12:38 AM   #9
Dieselwrencher
Grendel, I wanted to say thanks again for your input on this thread. I had to come in here and find it again because I was having issues getting a power steering line for another project I am building. Once I found the thread it was a no brainer. Thanks again!
Old 08-26-2008, 12:50 AM   #10
msgross
msgross's Avatar
only issue would be that 67 and some 68 frames are flat and the box won't bolt up without an adapter or spacers on the frame. Or some people "dimple" their frame with a BFH and a torch.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
