08-01-2008, 01:17 AM | #1 |
The Original HotRod KnifeMaker
Harbor Freight Sandblaster HELP
I borrowed a canister style sand blaster to do my step fenders [they won't fit in my cabinet]. The blast tip keeps clogging- using fine sand- what are you guys using in yours?
My compressor puts out plenty of pressure- is sand too coarse? It has a very small tip, compared to the gun in my cabinet.... TIA
Dave 69 GMC SWB 2WD 454 Turbo 400 |
08-01-2008, 01:32 AM | #2 |
Hollister Road Co.
Re: Harbor Freight Sandblaster HELP
You may need a bigger tip or run a air dryer so the sand won't stick together and clog the tip
08-01-2008, 02:12 AM | #3 |
Resident of Here
Sand can warp the fenders if you arent a pro. Try soda blasting.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
08-01-2008, 07:06 AM | #4 |
There might be moisture in the air line mixing with the sand that's causing that.
1997 GMC Sierra Ext 1965 Mustang |
08-01-2008, 07:27 AM | #5 |
Retired Air Force Veteran
I have a canister type from Harbor Freight and this is the same problem I have. Definetly the moisture in the air line.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
08-01-2008, 10:29 AM | #6 | |
The Older Generation
http://67-72chevytrucks.com/vboard/s...=soda+blasting LockDoc
08-01-2008, 10:33 AM | #7 |
PROJECT 7DEUCE
I also have the moisture in the air line problem anyone know how to fix it??? Also you guys with blast cabnets what aire pressure are you running?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-01-2008, 11:21 AM | #8 |
i have 3 water seperaters in my lines going to my blast cabinet do to high humidity and being less than an 1/8of a mile from the ocean
cabinet blast pressure for me varies according to what i'm blasting lowest effective pressure seems to be 50 on aluminum and brass stuffup to wide open i50 on things like rusty steel wheels//i use black beuty i think the name of the stuff in my cabinet i drink soda all sand is not the same/// i've found that playground sand sucks for blastind due to trapped moisture content and inconsistant size// i always used bagged silica sand size#00 that is manufactured expressly for blasting and always screen before loading into blaster and have very few if any issues with clogging but i have a pressurized pot which is a far superior way to go compared to the $20 cheapo systems/// never had a warpage problem with sand in the 40+years ive been blasting either
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 08-01-2008 at 12:56 PM. |
08-01-2008, 12:17 PM | #9 |
I run 60# of pressure in my cabinet with glass beads, more pressure would be nice for the rustier things, but the media wears out much quicker too. I've recently purchased some rubbermaid containers that are low profile and fit under the hopper. This way I should be able to quickly switch from glass beads to sand if I need to do the crusty stuff.
I agree on the can vs. pressure pot blaster. I gave away my canister and now use the HF 40# pot on everything that won't fit in my 48" cabinet. I've only ever used sand and glass beads for media. If you feel the blaster is plugging due to moisture, put your finger (with a glove on) over the hole in the gun and force the air back up the feed line to clear it out. I have to do this with the blast cabinet in the summer when it's humid out.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
08-01-2008, 01:49 PM | #10 |
PROJECT 7DEUCE
Thanks guys ill have to try between 50 to 100 before I just turned it up as high as it would go figureing more is better.... not always I guess..
08-01-2008, 04:59 PM | #11 |
I have a harbour freight sand blaster and I was having the same problem. I use a sreen to sift the sand before I blast and I do not have a problem anymore. I am also in Arizona so I don't have humidity problem.
08-01-2008, 11:56 PM | #12 |
I had a lot of trouble using the harbor freight sandblaster until I bought a better nozzle (ebay item 170245454986). Using (3) moisture filters and this nozzle solved my problems. Good luck to you!
Shovelhead |
08-02-2008, 01:12 AM | #13 |
Good stuff, guys. Thanks!
Where do they carry black beauty? Don't want to pay to have it shipped... I need a filter in my shop line anyway, guess I have to bite the bullet and get one tomorrow and get it hooked up. I use silica in my cabinet and leave a light in it turned on year-round. While I was trying to get the cannister going last night I had to change the quick-connect air fitting and decided to do a couple things: Put together two male and two female adapters. Then when I use something borrowed I won't need to change any fittings- just use the adapters. The second thing I am going to do is change the tip on the cannister hose to use one of the quick-change male connectors as a tip for the blaster- reversed- they have them for sale everywhere and they are cheap. Thanks again for the input. Dave
08-02-2008, 01:39 AM | #14 |
I have a HF blaster and I can't get it to work. I gave up on it. I bought a cheap $18 handheld and it's great. My local HF has black beauty in stock.
