Old 08-01-2008, 09:33 AM   #1
sluginxlt
sluginxlt's Avatar
steering gearbox ,what years?
my 67 has a sealed steering gearbox , a powersteering pump with the hoses running to some hydrualic cylinder on the tierod. and of coarse it doesnt work. will a normal powersteering gearbox from a newer truck swap right in? and will my powersteering pump work with it? what year trucks can i pick from and also is there any other parts i need to get along with it?
sluginxlt is offline   Reply With Quote
Old 08-01-2008, 11:57 AM   #2
jimmydean
jimmydean's Avatar
Re: steering gearbox ,what years?
I used the box off a '75 and it was a straight bolt in. I know the pumps are the same, but I don't know about the lines.
My '69 was manual and I pulled the box and pump off the donor.
<edit> '73 to '87 should all be the same.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 08-01-2008, 12:08 PM   #3
Rodms
Rodms's Avatar
Yes I think thats right I took my power off and put a manual steering box off of a 1971 and it bolted in the same holes as my power steering box did (1980) c10
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 08-01-2008, 04:51 PM   #4
scotts62
One day...
scotts62's Avatar
Ya i know one from a 73 sub will work, it was on my 62 and is now on Joe231's 66
Scott
93 crew cab build
Project 62
Old 08-04-2008, 09:18 PM   #5
ERASER5
ERASER5's Avatar
Or you could fix you ram assist power steering. All of the parts are still made. Corvette used the ram assist for a lot of years. There is a FAQ on repair parts and where to get them.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-06-2008, 05:10 AM   #6
oldspowered67C10
If Im not mistaken, 67s dont have the bump in the frame to accept the later style powersteering box. Im not sure if the holes will line up either. It can be done but you might want to search on the topic first to see what others have done.
oldspowered67C10 is offline   Reply With Quote
