08-01-2008, 10:24 AM | #1 |
Who's still running w/ stock gas tank?
I'm at my wit's end with this gas smell in the cab. I thought I was on to something when I found that my 70 CST-10 (no vent in tank) did not have a vented cap on it. I bought a vented cap and the gas smell in the cab is still very bad. Every time I drive it (even with the windows wide open) I arrive at my destination reeking of gas fumes. I've sealed up the sending unit with a shallow metal peanut can and duct tape to "run a test" to see if that was leaking fumes....still stinks with the can in place....I've poked around underneath as best I can to see if there are any leaks....Obviously I can't see in back underneath completely without removing the whole tank...I'm just wondering if I need to remove it and locate the tank elsewhere....I hate to do it because I know it's going to be a big job. How many of you guys are still running around with the tank in the cab...in it's original location? Is it the nature of the beast? Does it have to be relocated to get rid of this gas stench or do I have a tiny leak somewhere where i can't see it?? There is absolutely no evidence of a leak anywhere, yet I have this nasty gas fume problem!! Please help with any advice whatsoever. I do not have a cardboard/carpet cover for the tank...Is that part of the problem?? Thanks, Bob
I'm a grateful Christian not perfect in any way, but always striving to become better with Christ's help. I'm grateful for what He did for me on that cross at Calvary. I hope there is a desire in your heart for the same: If you confess with your mouth that Jesus is Lord and believe in your heart that God raised him from the dead, you will be saved. Romans 10:9 |
08-01-2008, 10:43 AM | #2 |
I have a radical idea!
Re: Who's still running w/ stock gas tank?
I am running in cab tanks in all my trucks, and none of them have a gas smell. I have seen them leak fumes around the sending unit. I have also had to reseal a few filler necks, but when everything is sealed up, you don't smell it unless you take a hard left turn with the windows down. Even then, it only lasts a few seconds, and it is a tradeoff I'll make to keep from installing a Blazer tank or an ill fitting fuel cell and ruining a bedside or floor with a filler. I actually like the look of the filler on cab (mainly because we'll never see that again on new trucks) and I don't like looks of a fuel tank hanging down in the rear. JMO
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
08-01-2008, 11:09 AM | #3 |
I use the stock tank in my 70. Other than the occasional wiff around the vented cap I don't have any smell either. Even when it does happen it's only for a few seconds. Good luck finding your source.
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
08-01-2008, 11:28 AM | #4 |
Junior Member
Both of my trucks still have tanks in the cab and the only time I have a gasoline smell is like the others.
It is not super hard to take the tank out if it is empty, but I think it works best if you have two people, especially when working the tank neck out of the rubber piece on the side of the truck. Some times the seat belts have to be removed where they bolt to the floor close to the bottom of the tank. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
08-01-2008, 11:29 AM | #5 |
I still have the in cab tank in mine, I did put a new filler neck cover and a new cap. It does not smell at all inside the cab ever. I dont drive my truck every day either as it is mostly driven to car shows and cruises so if it smells I would notice right of way, so far so good. Take the tank out and have it pressure tested and check the fuel sending unit would be my fisrt choices.
Good Luck!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
08-01-2008, 11:33 AM | #6 |
Always wrenching!!
i have a vented in cab tank and i have it hooked up to my 5.3L. get a lil gas smell but nothing that makes me sick or anything. maybe i should try and seal the sending unit hole better.
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
08-01-2008, 11:46 AM | #7 |
I was smelling gas pretty bas one in my ;67 C-30 ramp truck, and it ws the sending unit. I put bead of Right Stuff silicone sealant around the sem and I've never smelled it again. That was about 6 yrs ago, and it has held up great.
08-01-2008, 11:46 AM | #8 |
Stock tank no smell at all.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
08-01-2008, 12:00 PM | #9 |
I hated my tank in the cab. I kicked it's ass out a couple years ago. Never looked back.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
08-01-2008, 12:25 PM | #10 |
I'm running stock tank inside of cab as well on a daily driver. The only time I smell fuel is right after I fill it up and on an occasion with the windows down. However when I get home from work, my wife tells me I smell like truck..lol
08-01-2008, 12:30 PM | #11 |
Loving the Jimmster
i still have mine but i am changing it asap!!
08-01-2008, 01:14 PM | #12 |
Stock tank here... too much trouble to move it outbound, and keep it looking nice while being accessible.
08-01-2008, 01:25 PM | #13 |
Active Member
68 GMC and 69 Chevy both with tank in the cab. Occasional smell of fumes in the summer time but nothing that is offensive.
After seeing some trucks with the tanks in the back, I have decided to keep it in the stock location. Like some others, I like the stock look. If I do decide to change in the future, I'll probably go with a smaller tank that's not too bulky. Something like a 16 gallon one. |
08-01-2008, 01:38 PM | #14 |
Size Matters
My tank is behind the seat where it belongs and no fuel smell.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! |
08-01-2008, 02:37 PM | #15 |
Most people have NO idea that my fuel tank isn't where it's supposed to be
Can you spot what's different
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-01-2008 at 02:38 PM. |
08-01-2008, 02:39 PM | #16 |
Mine is also stock / in the cab and no fumes at all. Sorry Im no help, but i hope you can get that figured out. Mine has never leaked so I've never messed w/ it-
Rottenwood Garage 1970...71...72 C1500 aka Orange aka Sideshow Bob 540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600 2 Tons of Fun |
08-01-2008, 02:46 PM | #17 |
RIP BigDaddyDave ~7-23-09~ You will be missed~
The day i bought my truck i noticed a strong oder of fuel. I started checking around and found a tiny hole under the tank,sealed it up with some JB Weld,smell went away for good.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action! |
08-01-2008, 03:00 PM | #18 | |
Looks good at 20-ft .....
Hope mine looks that good, when I get one of those "round-tuit" things. Got the tank, just not the time & motivation. And the round-tuit. |
08-01-2008, 03:18 PM | #19 | |
The Older Generation
LockDoc
08-01-2008, 04:51 PM | #20 |
its all about the +6 inches
odds are, it is around the filler neck. I have seen quite a few leak from there, and the best that I can tell, it's from being lazy and leaning on the pump nozzle when filling up.
08-01-2008, 05:22 PM | #21 |
I would check you filler neck and take a flash light and see if you have any running done on the inside of the cab. They are not hard to pull. What condition are the lines in....dry rot, splitting
1972 c-20, 350/350, dana 60 w/456 gears(no Posi) |
08-01-2008, 05:32 PM | #22 |
Size Matters
Well I can but I read your build thread and I saw the truck in person!
08-01-2008, 05:32 PM | #23 |
Size Matters
Does the metal crack where the neck meets the tank?
08-01-2008, 05:39 PM | #24 |
yep. It's actually brazed on, and that's what cracks.
08-01-2008, 06:49 PM | #25 |
They call me the Breeze...
The in cab tank is one of the few original items that I have that hasn't rusted into oblivion here in the rust belt.
I will never move it for that simple fact alone...
Mike 69 K20 "Beer is proof God loves us and wants us to be happy"....Ben Franklin |
