Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 08-01-2008, 06:12 PM   #1
PA-IndianRider
PA-IndianRider's Avatar
Heater-Vent-Defroster control problem-any guesses
Just picked up a '81 el Camino yesterday.
Driving it everywhere right now which means I'm starting to notice ALL the little things that need attention/fixed. The heater/vent/defroster control moves just fine but not much air is comming thru.... sounds like the duct work is closed with the fan running.
As i recall the "slide" control when moved to whatever "chosen position" opens the duct work to the desired function ... which I believe is activated by a vacuum switch..... OR????
Any Guesses????? Thanks....
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
Old 08-01-2008, 09:19 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Heater-Vent-Defroster control problem-any guesses
My best advise is to go to www.motorbooks.com and see if they have a manual for it.I would imagine they will have a "Haynes" but I don't know about others.IIRC and there is no guaratee of that,that era would be vacuum activated.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-01-2008, 10:54 PM   #3
PA-IndianRider
Reason I mentioned I thought it could be a "vacuum activated" system is I had a '84 Poncho STE NEW back then and had the same symptoms... I took it to the dealer.... Mr "NOT-Goodwrench" tore the whole dash apart trying to figure out the problem ..... THEN MR GOODWRENCH came back from being on vacation for a week.... replaced a simple part & all was well.... I recall it was something related to the system being vacuum operated.... in other words the control was NOT operated by "cables and levels".... afterall that would be so simpleand also "easy" to fix..... Thanks for the tip about finding a "Haynes" or.... a "surfing here I go"
John aka "Milner"
Old 08-02-2008, 10:17 PM   #4
airdale94
airdale94's Avatar
Check under the hood for a vaccum pod, black plastic about the size of a baseball. Check the line going to it and going through the firewall.
airdale94 is offline   Reply With Quote
Old 08-03-2008, 12:25 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
movin to general discussion
