Old 11-13-2002, 04:27 PM   #1
Kiss My SS
Kiss My SS's Avatar
HEI in a 72 GMC Jimmy?
Does anyone know if you can put an HEI distributor into a 72 4x4 without modification to the firewall? I was told that it wouldn't fit but I wanted some other opinions. I am tired of dealing with points style distributors. thanks for any input you might have. By the way, I am new. Good to be here.
1972 GMC Jimmy 4x4
1985 Chevy Monte Carlo SS
1996 Saturn SC-2
1996 Ford Explorer XLT -Wife's rig
Kiss My SS is offline   Reply With Quote
Old 11-13-2002, 05:30 PM   #2
GMC71k20
mine fits but its close and im pretty sure the motor is in the 6cyl position because its way back in there. if your really worried you should get an aftermarket HEI dizzy because theyre much smaller.
GMC71k20 is offline   Reply With Quote
Old 11-13-2002, 06:31 PM   #3
Kiss My SS
Kiss My SS's Avatar
I would go with a new one but I am a poor college student. I figured that there were plenty of vacuum advance HEI's laying around at junkyards and I could get several and make one good one to use. I think it will fit. My engine is way back there too. Does anyone else have experience with this?
1972 GMC Jimmy 4x4
1996 Saturn SC-2
Old 11-13-2002, 11:15 PM   #4
Mike C
Mike C's Avatar
The 4 wheel drives all have the motor mounted back in the firewall recess. This is done in order to make the front driveshaft as long as possible. I just barely got my points distributor in and out on my Jimmy. I went with an MSD ready to run electronic distributor that uses the window style cap. Let me keep my new wires I had bought as well.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-14-2002, 08:58 AM   #5
Blazer1970
Blazer1970's Avatar
Mine had an HEI in it when I got it. It fit, and you could get the distributor in and out as long as the cap was off. It was very close to the firewall though. The closest thing to it was the end of a screw that sticks through the firewall in that location that holds on part of the heater box on the inside of the cab. My truck has A/C, and that screw might not be there in a non A/C cab. The HEI will normally fit like this in 4X4 trucks, but you better have good motor mounts. I would also have someone brake torque the engine while you watch for clearance between the distributor and firewall as the engine rocks on the mounts. I swapped my factory HEI out for an MSD small body HEI.
Also, GMC71K20, all '67 - '72 four wheel drive V-8 trucks have the engine mounted in the "back" (6 cyl.) location.
Blazer1970 is offline   Reply With Quote
Old 11-14-2002, 11:43 PM   #6
MJN
MJN's Avatar
The HEI in our Blazer is really close, my dad massaged the firewall a little (without me there) so it isn't as bad as a stock firewall. The wires farthest back against the cap may rub through from rubbing on the firewall, this happened to two of mine and I rerouted and no rubbing anymore. The only way to get it out is without the cap on and then it is still close.
Old 11-17-2002, 05:12 PM   #7
Beast388
Suburbans RULE!
Beast388's Avatar
I have a Summit HEI in my 4X4 Suburban. As previously stated, it is close and the only way to remove the distributor is with the cap and rotor removed. There is about a 1/4 to 3/8 room between the cap and firewall. I would recommend leaving the stock HEI wire retainer off. I would say do the swap....it's close but will fit.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 11-17-2002, 05:53 PM   #8
72C10chevy4x4
UK Wildcat Fan!
I didn't know what an HEI was in my truck-especially when walking in to the auto parts stores and looking for a 'stock' vacuum advance unit :-)
anyhow, my truck came w/ an HEI unit, possibly from mid 70's vehicle. It fits-but is tight-only problem I had was with the wires (1) not being long enough. I've got the 4 speed engine-not sure if there in how far a manual versus an automatic pushes the engine back.
Paul
72C10chevy4x4 is offline   Reply With Quote
Old 11-17-2002, 11:58 PM   #9
Kiss My SS
Kiss My SS's Avatar
Well, guys, I got an HEI out of a mid seventies 3/4 ton 4x4. I took it apart and it all looks good, I am planning on putting it in middle of next week. I am having my dad mail me several new HEI parts that I had at home for my Monte Carlo SS as well as 2 sets of plug wires so I can pick the best wire from each set. It should be all good and not a moment too soon. My points distributor is starting to screw up. I was towing my friends car on a trailer and anytime I got at or above 3000rpm it started missing really bad so I had to tow it at 30mph or less. I assume that it has something to do with the weights or vacuum advance but I dont want to mess with it. I'll let you know how it turns out. Thanks for the advice.
1972 GMC Jimmy 4x4
1996 Saturn SC-2
Old 11-18-2002, 08:46 AM   #10
72C10chevy4x4
UK Wildcat Fan!
I found a weight kit for the advance portion at Pepboys for ~$7.
Old 11-18-2002, 01:11 PM   #11
Dean
Dean's Avatar
I have GM HEI distributors in three of my 71 K20s. It is close but it will go in there. I'm not sure I would want to be doing any radical 4x4ing with it like that though. Wouldn't take much movement to crack the cap.
Dean is offline   Reply With Quote
Old 11-19-2002, 06:51 PM   #12
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
HEI in my '69 and it fits but, as with everyone's, it is tight. I have heard of people doing some "Modifications" to the firewall with a big hammer.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-21-2002, 03:07 AM   #13
Kiss My SS
Kiss My SS's Avatar
Well, guys, Igot it in. Runs Awesome. Come to find out that the reason it was missing above 3k was one of the little hooks that holds the cap on was off so the cap would wobble and miss. Oh, well, i guess I never noticed that before. anyway, I am happywith the HEI, thanks for the help.
1972 GMC Jimmy 4x4
1996 Saturn SC-2
Old 12-14-2002, 04:16 PM   #14
tai
tai's Avatar
buddys k5
his stock 72 fits a stock chev\gm hei on a 350
msd makes a billet one peice, raced bearing(no fing bushings) hei with vacum advance thats sick and should fit nicely
tai is offline   Reply With Quote
