08-02-2008, 06:50 AM | #1 |
Need Ideas.. Let me c your Sub & Amp pics
Going to add a subwoofer & amp see pics...
08-02-2008, 06:57 AM | #2 |
Re: Need Ideas.. Let me c your Sub & Amp pics
I can take a pic of my amp since it's no longer in the truck but the sub is still in the truck under the passenger side of the seat. The amp was mounted under the drivers side of the seat and the amp is under the passengers side. The sub is an 8" and it put out plenty of bass. I had plenty of people think it was at least a 10". The amp and sub are both Alpine.
Here is the amp. When the amp was in the truck you could not see it because it was mounted close to the center of the floor under the drivers side and it is not one of those big amps. It still put out plenty of power even though it wasn't large. You could see the sub from the passenger side though but the box was covered in carpet to match the interior. Whenever I finally get the truck fixed up again I'm going to see if I can fit a 10" under the seat because the 8" finally busted after all those years of playing loud rock music. Last edited by Chevyman680063; 08-02-2008 at 07:12 AM. |
08-02-2008, 12:20 PM | #3 |
I got a box built to go under the back seat of a 95 chevy extended cab, very low profile, had 10" Rockfords in it. Thinking of trying to get it to fit under my 69 seat
1969 4x4 Nothing beats a good rock drill and some dynamite |
08-02-2008, 02:38 PM | #4 |
I say go for it. It may touch the bottom of the passenger side of the seat but you don't sit on that side when driving so you won't feel it. I think the girls like the vibrations coming from under the seat anyway.
08-02-2008, 02:50 PM | #5 |
If you put one under the seat, you need to notch it up over the trans hump to get all of the airspace you want (at least 1 cube per sub, in most cases). Rest the box on the forward seat bracket hump and use a 3/4" spacer in the back; down fire them. I've heard there are some new crazy thin subs. A few years ago, these were the best sounding thin monsters I could find. You may be able to get away without blocking the seat up.
2 Kicker CVR 10's in a sealed, chambered box with 1 cube each. Powered by a Rockfos 701s.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
08-02-2008, 03:05 PM | #6 |
Sorry I don't have a picture of it installed. It does fit nice behind the seat! The three 10's I have mounted sound awesome!!!!!!!!
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
08-02-2008, 03:13 PM | #7 |
Thats nice man! I may do something similar when I put get around to putting a fuel cell in it
08-02-2008, 04:35 PM | #8 |
Daaaaang, that's gonna be alot of bass there. It looks nice too. Just be careful with how loud you have your stereo or you're gonna be deaf before too long. WHAT?!?! I SAID YOU'RE GONNA BE DEAF!!!!
08-02-2008, 05:53 PM | #9 | |
Hey 70short what the dimensions on your box?
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 Last edited by GKsport67; 08-02-2008 at 05:53 PM. |
08-02-2008, 06:06 PM | #10 |
I've got a box that held 2 10's in my ford dually that I think will fit in my C10 once I get the gas tank out. It had to comp vr 10's in it and sounded pretty good. I think I'm going to go that route since my buddy buckets don't hinge anyway to be able to use the space for anything else. Stash the amps under the seats and it should work good.
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc. My new build thread: http://67-72chevytrucks.com/vboard/s...17#post2861817 Best pass with the old dragtruck: 5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003 Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup 5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004 |
08-02-2008, 08:17 PM | #11 |
Here's mine. It's all installed now with a 5 channel SoundStream amp mounted just left of the sub. Just one shallow 10 inch is perfect for me.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
08-02-2008, 08:50 PM | #12 | |
EDIT - Nevermind, just found it in your build thread. That is a sharp truck. Last edited by Chevyman680063; 08-02-2008 at 08:52 PM. |
08-02-2008, 09:37 PM | #13 |
VA72C10
Nice setups...
08-03-2008, 06:24 AM | #14 |
08-03-2008, 10:37 AM | #15 |
Old member
Pictures of the perment install of the sub enclosure and amp. I bought the grey carpet and covered the front panel. I had to move the amp after I got the passenger seat in because it wouldn't let the seat go back fully. Oh well! Amp is now under the drivers side seat.
400 amp for the 2 subs & 2 3ways under the seat. 100 amp behind glove box for the 2 tweeters & 2 ways in the center of the dash. Brooks & Dunn sound awsome when I crank it up! You can see in this picture that the passenger side seat want go all the way back. I have a 6' son and that just wouldn't do! Ha!!!!! That's him in the background.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 08-03-2008 at 10:39 AM. |
08-03-2008, 12:31 PM | #16 |
Loving the Jimmster
08-03-2008, 12:54 PM | #17 |
TOTY 2006
Here are some of my setup. I have my highs in the stock dash speaker frame, and used two amps with crossovers and two mids with a one 12 behind the seat.
