Old 05-08-2002, 01:53 PM   #1
chevyhouse
BEER-Vacation in a can...
chevyhouse's Avatar
Post brake pedal return spring
i just did the power and front disc convertion on my 69' c-10 and am having a problem with the brake pedal not returning with the vacumm hooked up to the booster, it returns fine with out the booster in play. we replaced the booster already and had no luck. the brakes work fine just the pedal does not return, how can i tell if the return spring is strong enough? i am thinking that could be a possible problem.
Kurt
94' Camaro
85'Plymouth Horizon
69' C10, 350/4spd, lwb, fleetside long box, 3.5"/5" drop, power and disc conversion
early 80's Schwinn 18 spd
[This message has been edited by chevyhouse (edited May 08, 2002).]
Kurt
03' Trailblazer
69' C10 "SPSHL-K", 388 stroker/BTO 700R4, 2400 stall, 3.73 posi, lwb, fleetside long box, 3.5"/5" drop, 18" Budnik
2000 Yamaha V-Star 1100 Custom
For Sale-87' V10-4x4, 408/700r4, 4.10's PM for pics
chevyhouse is offline   Reply With Quote
Old 05-08-2002, 04:35 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
if its ocnnected correctly under there then it should be fine, i highly doubt it could weaken up sp much thaty it wouldnt do its job. whats the exact problem ? is it coming back up and stoping at a certain point or is the pedal rod too short and needs to be adjusted, or ?
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
*many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham
current fleet: -71 C-10 350/CH465/3.07- basketcase, #1
-90 Cavalier 2.2L sky blue, a driver
-84 Z28 5.0L/700R4/3.73 daily driver
-84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2
-82 purple Trans Am, project #3
*Paint is overrated*
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 05-08-2002, 05:09 PM   #3
chevyhouse
chevyhouse's Avatar
Post
the exact problem is that with the booster hooked up the brake pedal stays wherever you put it, push it in, pull it out, all the way/halfway whatever. the brakes work exactly like the pedal is positioned.
Kurt
94' Camaro
85'Plymouth Horizon
Kurt
03' Trailblazer
Old 05-09-2002, 01:58 PM   #4
chevyhouse
chevyhouse's Avatar
Post
ttt-any ideas???
Kurt
94' Camaro
85'Plymouth Horizon
Kurt
03' Trailblazer
Old 05-09-2002, 02:26 PM   #5
HuggerCST
HuggerCST's Avatar
Post
I had the exact same problem a while back. My problem was that the bolt and nut that goes through the pedal was binding up. I loosened the nut a little, and it worked fine.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
