Let's see your throttle cable on your AD truck
With a 350.
Re: Let's see your throttle cable on your AD truck
This is a build picture from under my hood, but I'm needing to know how ya'll have your throttle cable ran to your carb from out of your firewall.
I am watching this thread!!
I am looking for a late 50's early 6o Corvette linkage that bolted to the bellhousing, no luck so far!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
Well, mine had a Lokar but it was cut too short and came apart after driving it for a little while. I just really need to run a longer one with a loop in it.
hope this pic helps.
Question,
I see that you have your shift arm from the steering column going under the brake arm (shortned), how has this affected the geometry of the indicator on the column? I am having a interference problem also
it was fine with the 350 turbo now with 700r4 it is off and it wont shift to first gear. there is a cable shifter they say works good but i havent seen it. if you find something to work good let me know ( column shift) thanks
I like Lokar products, but isn't there something from the bone yard that can be adapted ?
My throttle cable comes out of the fire wall too far away from my carb and has it at an awkward angle.
yep, call Lokar
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
I bought a Lokar cable shifter.....it did not work as well as other products I've bought from them. It shifted very hard.
Don |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I have the lokar eliminator pedal set-up the comes out through the bottom of the floor and then runs up to the firewall.. Ya may want to take a look at those.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#13 |
I've used the same setup as smittys50. Mine is even shorter, seems to work O.K.. Had to tweek it some to get it to come to idle smoothly, but I think I'll be happy.
