08-02-2008, 08:32 PM | #1 |
NP 205 won't go into low range all of the way
see the wreck:
http://67-72chevytrucks.com/vboard/s...to_threadtools Now , for what ever the reason 2 hi and 4 hi are fine but I can only partialy engage low range it goes in enough to think you are in and then it pops out when you put a load on it............the linkage seems fine and nothing in that area was affected when I crashed. For some reason it is like the front axle is engaging (that part of the shifting) but the low range will not go in. Any ideas?
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: |
08-02-2008, 11:10 PM | #2 |
Re: NP 205 won't go into low range all of the way
I feel realy dumb! I went out there about a half hor after posting this and couldn't for the life of me figure out what could have hurt that 205 transfercase...the things are beasts!
As it turns out this is the first time I went to engage it today to pull against the tree with and I discovered that the lever couldn't travel fully to get full engagement because of the boot that i didn't account for when i mounted it after the trucks floor mat was put in............ works just fine after i pulled the screws out that hold the boot down!!! I am emberaced! I wish all fixes were this easy................maybe my blunder wil help someone else.
