Old 08-03-2008, 04:07 PM   #1
f.monroe
f.monroe's Avatar
Picture request
Anyone running a set of Coys or TT2's in 20 inch on a truck only mildly lowered ? I am going to put something on the Black truck but I do not want to lower it more than 2.5/4 or maybe 3.5/5 . I will not be C-notching it so I wonder if I should stick with 18's like I had on the tan truck or wouls 20's look OK ? Thanks ,
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 08-03-2008, 05:04 PM   #2
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: Picture request
Frank, doesn't matter what you do that truck it'll look sweet. I personally don't care for the look of 20's on vehicles this old, looks great on late model stuff tho. JMHO, to each his own.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 08-03-2008, 07:34 PM   #3
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Re: Picture request
The 1st pic was a 5/6.5... I dont think 3.5/5 will be low enough to make it look "right". The 2nd pic is sitting at 6/8. If your doing a mild drop... I would stick with the 18" set up that u were running on the tan one. Its not C-notch... but I did have to trim the bump stops down as well.
CLASSIC87' is offline   Reply With Quote
Old 08-03-2008, 09:22 PM   #4
SCOTI
SCOTI's Avatar
Re: Picture request
I think the 20's will still look fine @ 3.5/5 drop & you won't be buzzing the stock front inner fenderwells constantly. Can't help ya' w/the Coys & mild drop but I'll put up a couple of the Coys on my 74. 20x8.5's w/5.25BS & 255/40's; 20x10's w/5.5BS & 295/40's.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-03-2008, 09:48 PM   #5
redrat
gearhead
redrat's Avatar
Re: Picture request
at 6/8 are you having any isues with the front tires rubing the iner finders??
2003 GMC Z71 Daily driver
1982 Chevy 2wd short bed, project,
boxerdra@hotmail.com
redrat is offline   Reply With Quote
Old 08-03-2008, 10:08 PM   #6
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Re: Picture request
The inner top side of the tire will when I hit dips at 40mph+... but not bad enough for "me" to raise it back up.
Old 08-03-2008, 10:18 PM   #7
SCOTI
SCOTI's Avatar
Re: Picture request
What was your combo again? Even @ a 20mph crawl, mine would buzz the top of the wells up front (I could not wedge my fingers between them).
Going back & focusing on the gaps between your wheel lips vs. fender lips compared to mine, I see more rubber on yours. So mine might be a hair lower?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-03-2008, 10:45 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Picture request
Frank, 20's will look just fine. If you don't lower it much, the larger wheel will look even better. Just adjust the gap with the proper tire, and your good to go.
Are you considering the polished, or gray center?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-03-2008, 11:11 PM   #9
SCOTI
SCOTI's Avatar
Re: Picture request
I agree. With the drop you suggested, some 20x8.5's w/245/45's & 20x10's w/295/45's would add a little more meat. 275/45's would also work out back & are a common OE size which might be cheaper.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-03-2008, 11:16 PM   #10
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Re: Picture request
3" spindle and 3" spring up front-20X8 w/5''BS and 255/40/20.. And I agree yours looks lower.
Old 08-03-2008, 11:32 PM   #11
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Re: Picture request
I think I'm in the minority here, but Coy's never really look as good to me unless they have a 40 series or lower tire. I think it's the lip design. I know the lip is flat instead of stepped, but the outer portion by where the bead sits seems kind of rolled up almost perpendicular. To me, that would spell 20s instead of 18s if I were going with Coys.
I've never had a set, mind you. That's just opinion and observation.
-- Will
killthewabbit is offline   Reply With Quote
Old 08-03-2008, 11:48 PM   #12
andresco50
andresco50's Avatar
Re: Picture request
I love your truck just drop it 3/5
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 08-04-2008, 07:49 PM   #13
redrat
gearhead
redrat's Avatar
Re: Picture request
this is what my 82 looks like at 6/8 drop. But im runing a big block with the big block springs and it still sits to low with a 3 coil and 3 inch spindle.So Im going to try a 2 inch coil and work from there. the way it sits in this picture the iner finder was rubing on the tire most of the time. I thought about modifying the finder but i want to see what it would look like raised up an inch first.
the tire sizes are 255/40/20 on 20/8.5 in front and 295/40/20 on 20/10 at the rear
Old 08-04-2008, 08:04 PM   #14
spr85gmc
spr85gmc's Avatar
Re: Picture request
20/22 255/40/20 front 285/35/22 rear 5/5 drop
spr85gmc is offline   Reply With Quote
Old 08-04-2008, 09:38 PM   #15
f.monroe
f.monroe's Avatar
Re: Picture request
Ken , If it is Coys then I like the grey center . In TT2's I like the full polish .
Frank
Old 08-04-2008, 11:20 PM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Picture request
Originally Posted by f.monroe View Post
Ken , If it is Coys then I like the grey center . In TT2's I like the full polish . Frank
Cool! I like those Coys too...
Articles-
"Refining Sierra"
Old 08-04-2008, 11:40 PM   #17
f.monroe
f.monroe's Avatar
Re: Picture request
Question , would the tire sizes Scotti listed above work on a 20x8 with 4.5 backspace and a 20x10 with 5.5 backspace ? 245/45/20 and 295/45/20 .
Frank
Old 08-05-2008, 12:20 AM   #18
Crush
Active Member
Crush's Avatar
Re: Picture request
Frank
Hey Frank,
Know this isn't a truck, but here's my blazer with what was a 4/6 with 20x8 4.5 bs and 20x9.5 5.5 bs running a 245/40/20 and 295/40/20's.
beautiful truck....I think anything you do to it will be fine
D.M.C -FF-
Crush is offline   Reply With Quote
Old 08-05-2008, 12:41 AM   #19
f.monroe
f.monroe's Avatar
Re: Picture request
Crush , Its your wheels that I am asking about . I am trying make up my mind .
Frank
Old 08-05-2008, 12:59 AM   #20
Crush
Active Member
Crush's Avatar
Re: Picture request
I figured.
Just want to make sure they are what you want.....not in a hurry or need to sell them. Last thing I want is buyers remorse from a board member.
If you'd like I can go get a pic of what they look like on my '79 as it sits. It's got about a 6/8 drop on it right now (looks like about a 6/9 drop with all the stuff in the bed...lol).
D.M.C -FF-
Old 08-05-2008, 08:18 AM   #21
f.monroe
f.monroe's Avatar
Re: Picture request
The pics I am after is a shot of how they sit in the wheelwells . How much clearance to the fender lip ?
Thanks , Frank
Old 09-01-2008, 11:06 PM   #22
Rollinsqrbdy
Rollinsqrbdy's Avatar
Re: Picture request
redrat like ur truck. Whered u get the grill?
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
