will this work or not
i was given a 1980 chevy 3/4 ton truck and was wondering if the spindles and disc brake set up would work on a 1960-1961 tortion bar front end. i also have the 3/4 ton rear end for the same doner truck. i don't mind having 8 lug stuff on my truck might change later to 5 lug when i have the money. please let me know if this is possible to bo with out to much modification. plus i am going to be running a 454 with th400 trans. thanks vince
vinnie 1960 chevy c10 frame with a 1966 cab 2002 dodge intrepid r/t 2004 chevy 2500 4 door short bed |
KOFFIN DRAGGER
Re: will this work or not
I think you could drop your whole x-member and install the newer stuff. It will be a waste of time to do it with the 3/4 ton stuff if you are going to do 5 luggars in the future. I would try to find the same vintage of doner truck in a 1/2 ton model. Just my $.02
If the life I live dont kill me, then I guess I'll never die! New updated stuff at www.kdrodworks.com My site still needs help, web guys and gals pm me. the best guys in the whole world: sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231 |
SOLD
Location: Poorest state in America(Breaux Bridge,Louisiana)
Don't think it will work
1966 CHEVY FLEETSIDE SOLD 11-29-9 TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2 |
i believe the cross member is the same on 3/4 and 1/2 tons. swap the whole thing, use the 8 lug stuff if you want, but you might have to swap the lower arms to get 5 lug stuff on it. would be lots of extra work swapping the rear diffs multiple times. i think if you want 8 lugs, go for it, but if you want 5 lugs wait and get the right stuff.
Should you decide to swap over to the 3/4 ton stuff - you can swap out the 3/4 ton 8-lug hub to a 5-lug hubs for 850+. Its a costly setup but ya gotta REALLY WANT THE 5-LUG BADLY to spend that kinda $$. I'll post the vendor info later - gotta run.
OK here is the info from www.geartechhd.com: THIS KIT WILL ALLOW YOU TO PUT 5. OR 6 HOLE WHEEL HUBS ON YOUR D60 FRONT OR YOUR D60 AND 14 BOLT REAR IT CAN BE PURCHASED WITH DISC BRAKE BRACKETS ALSO SO YOU CAN MOUNT 15" WHEELS ON THE AXLES THE KIT COMES WITH ALL THE WHEEL BEARINGS AND SEALS STUDS AND HARDWARE THE HUBS. HUBS W/T STUDS AND BEARING 895.00 pr. - NO DISC BRAKES. 1450.00 WITH DISC BRAKES. I beleive these can be ran with either the 14 bolt FF or Eaton H052 rearends.
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 Last edited by 64c20crewcab; 08-04-2008 at 03:59 PM. Reason: Update: Price Info... |
thanks for the info on all the comments and thanks for the link to the site for the adapters for the d60s
vince
is the '80 a 4x4?
no it is a 2wd 3/4 ton
alright, i'm sticking to my previous post then
the reason i am getting the 3/4 ton stuff is cause it is free. i am having a whole front of a truck delivered to me in a large dumpster he is giving me the chevy 350 motor th400 trans and all the front suspention stuff. the back of the truck was cut off behind the cab i am also taking the brake booster and valves. the other problem i have right now is that i just had my neck fused on the 28 of july so i am in a neck brace and cant do any thing for a while.so i might as well get all the parts i caqn use or trade right now since i am down for three months.
wish you a speedy recovery, sounds like you scored motor/trans wise but if you ever wish to go 5 lug you should probably just keep the brake booster, xmember and control arms.
Jonny
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR Last edited by sailed2japan; 08-06-2008 at 11:27 PM. |
#13 |
that is what i was thinking plus i proubly would never break anything in the rear end regardless of how much power in the motor i have plus it wiuld stop faster with the 3/4 ton front and rear brakes
#14 |
sailed2japan if i do use the 3/4 ton front end parts should i get 1/2 ton front lowering springs so the ride is not to stiff as to the weight of the 3/4 ton spring rate is alot higher then the 1/2 ton truck suspention. since i will be running a 350 and th400 trans. the rear springs should be fine in 1/2 ton but if i lower the front end then i would get lowering springs for the rear also.
thanks for our input and i like your .02 cents vincent
#15 |
with a 3/4 ton front x member could i run 1/2 ton spring so the ride is not to stiff
#16 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I don't see why not.....they are both the same OD.
#17 |
thanks for the info
#18 |
well got all the parts off of the 80 3/4 ton truck i got for free. i got the corprate 14 bolt rear end front x-member from wheel to wheel the brake master and booster the porportion valve 350 motor and th350 not a th400 but i have a th400 trans. which trans is better the 350 or 400? i also have all the stuff to covert the rear diff to disc brakes set up.
vinnie 1960 chevy c10 frame with a 1966 cab 2002 dodge intrepid r/t 2004 chevy 2500 4 door short bed Last edited by mnky30; 08-15-2008 at 12:30 AM. |
#19 |
Sounds good! I'm gonna grab late model 3/4 front end on labor day weekend. local parts yard is havin a sale that weekend. As for the trans go with the 400. I'll plan to be using a 700R4. Good luck with your swap!
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
#20 |
thanks the only thing is i will be watching my buddy's do the work i had neck surgery 2 weeks a go so i can't do any of the work my self except hand them tools. o well at least it is going to get done and i can watch and take pics.
#21 |
well tore the engine down today and it had recently been rebuilt every thing is real clean,there it still hone marks in the block its a 4 bolt main and i'm putting a rv grind cam in and performer intake on and shorty headers. next week i'm going to start on the front end swap then to the rear end swap. i'll post pics soon.
#22 |
my buddy's tore the old front torson bar front end out last night and we setthe frame on the 3/4 ton 80s x member and will start to bolt up the front end in a while.my project might be on hold for a while be cause i have 2 horses a female and her 6 month old baby boy that we started to casterate today and ended up going up to uc davis medical center for emergency surger that will set me back like 6000-7000 dollers. so unfortinitaly the truck might be sitting a while longer then i planed. have to pay for the pets we love first then we get to play with our other toys. but in the mean time i am spending as little cash that i might have left over withch is almost none goes to the truck .o well little set backs i guess right. i guess that is why they say life has its ups and downs right!!!!
#23 | |
Hollister, CA.
![]() Join Date: Sep 2006
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
#24 |
I think you should go with the TH350 trans and keep the 400 for now. The 400 steals more HP to turn it and 350's are pretty tough. Plus if the engine was rebuilt then maybe the tranny was too. But use the TH400 if you are going to do alot of heavy towing. The 350 in my 4x4 towed just fine when I had it. It was still working even after I pulled it. I put in a 700R4 instead with a NP208 transfer case from an 88 burb. This is in my 79 4x4.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 08-20-2008 at 10:11 AM. |
#25 |
chevy fleetside the reason i was going to go with the 400 is that i had it rebuilt and the frame has been set up for the 400 mount and at 350 motor mounts and the 350 is just a little shorter than the 400. i am keeping the 350 as a back up trans and when money permits me to i am going to build a 383 stroker to go in the truck.
