08-03-2008, 07:22 PM | #1 |
Unknown material found
Hi, I just completed sandblasting a frame from a 72 c10 and where the rear coil springs mount to the frame there is some rust through. I thought I could just build the few holes with some weld but what I thought was metal is not. Does anyone know what this filler material is between the frame and spring perch, a magnet will stick to it and it's very brittle. I've repaired the holes by welding a 1/8th thick plate over the spring perch but I'm now concerned about this filler material that is falling out, hope I'm making sense.
08-06-2008, 02:07 PM | #2 |
Re: Unknown material found
Permatex 25909 Liquid Metal Filler that meets all the description you gave. I found it online here Amazon.com: Permatex 25909 Liquid Metal Filler,... but see it in my local autoparts store all the time usually wrapped part way around a penny hanging from a chain.
08-06-2008, 10:23 PM | #3 |
If it's between the spring perch and the frame my guess is that the "filler" is road dust - gravel, grit, sand, etc.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
08-07-2008, 07:45 PM | #4 |
Yes there was gravel,grit and sand but this stuff is solid and can be picked up with a magnet, shatters if you hammer on it and explodes if you hit it with a mig welder. I found it between the halves of the trailing arms as well and it seems to have swelled up and pushed ( bulged ) the c channels between the rivets.
08-07-2008, 10:02 PM | #5 |
3DrDwn--the 'burb not the band
Sounds like some PO couldn't find his JB weld and jammed some permatex in as a "suitable" repair
Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
