Help with vin?
Can anyone help id this truck? KE247T131045 DD
its all about the +6 inches
Re: Help with vin?
there's a decode right here on 67-72chevytrucks.com
http://67-72chevytrucks.com/Chevyear.html k 4X4 E v-8 (unspecified) 2 3/4 ton 4 cab and bed (unspecified 7 1969 T Tarrytown build plant 131045 the 31045th truck built at that plant, on the first assembly line, for that model year run Last edited by Longhorn Man; 08-03-2008 at 08:09 PM. |
Re: Help with vin?
Thanks, tells me its an orig v8.How about checking factory opts, the glove box is all messed up.
Re: Help with vin?
that was probably your only shot.
If you pull the seat out, flip it upside down, and look in the springs, you MIGHT see a 41 year old piece of paper stuffed in there. It could be in the seat back also, or on the back side of the fuel tank... but on these trucks they were normally stuffed in the bottom of the seat. This would be the build sheet. It shows every option, and every little tid bit (most of what can not be decoded) that your truck rolled off the assembly line with. |
