Old 08-03-2008, 08:16 PM   #1
Purduegmc
Electric Fuel Pump Plumbing???
I am about to put an electric fuel pump on my truck and was wondering how other have routed their lines and what you used (braided, reworked stock line, stainless, etc.). Thanks for the help and pictures are welcome!
70 GMC 1500 2wd lwb
00 Chevy 2500
Purduegmc is offline   Reply With Quote
Old 08-03-2008, 08:48 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Electric Fuel Pump Plumbing???
You'll want to place it as close as you can to the tank. An electric pump likes to push the fuel, not push it.
Mounting it with a rubber isolator is a good idea, the buzzing would get old if it is a driver. Old shock bushings are good for this.
If it is a high output unit, a relay is a good idea on the power source.
An oil pressure cut off is a VERY good idea. If you don't have it, the pump will go as long as the ignition switch is on, and if you are in an acident, it'll go on and on dumpin fuel where ever.
Old 08-03-2008, 09:25 PM   #3
shortbed70
shortbed70's Avatar
Push not pull.. I am going to run a fuel cell under the bed with th pump mounted on the passenger side frame rail beside the cell and run through rubber high pressure lines to carb.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 08-03-2008, 09:33 PM   #4
Longhorn Man
sb70... you plan on running a rubber line from teh back of the truck to the front of the truck... for fuel delivery?
