Old 08-03-2008, 08:55 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Can i use this alternator???? Close to motor completion.
Im assembling the motor (454) and putting on all the accessories. The alternator is from an 81 chevy. My truck is a 71 stepside... Can i run that alternator??? What alt do i need if that doesnt work? Just buy an alt for a 71 chevy big block?
Any belt routing pics anyone can post up? Thanks for the help.
lyrikz is offline   Reply With Quote
Old 08-04-2008, 12:38 AM   #2
lyrikz
PITbut
lyrikz's Avatar
Re: Can i use this alternator???? Close to motor completion.
Anyone??????????????????
Old 08-04-2008, 10:39 AM   #3
kwmech
You will hafta do a little bit of rewire to make it work properly, but it will bolt right on
Old 08-04-2008, 10:43 AM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Can you post a pic of your power steering set-up? You can run any alt you want just need to make sure the wiring is set-up correctly. Has the truck been rewired most aftermarket wiring kits have the extra alt kits included..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-04-2008, 01:41 PM   #5
lyrikz
PITbut
lyrikz's Avatar
No, wiring looks to be new original from the looks of the wires.
So, i believe my old alt. was a one wire alternator. This alternator has i believe 2 blank spades and a terminal on the rear of it. How do you wire the alternator???
Any particular pics you need on the PS setup.???
Old 08-04-2008, 04:11 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
where does this bracket go???
MEMBER #6377
Project "7DEUCE"
Old 08-04-2008, 06:11 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
try this----http://67-72chevytrucks.com/vboard/showthread.php?t=119379
Or this----http://www.chevelles.com/techref/tecref14.html
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-04-2008, 06:35 PM   #8
lyrikz
PITbut
lyrikz's Avatar
that bolts to the power steering pump under the actual pulley.
Old 08-04-2008, 07:08 PM   #9
truckdude239
truckdude239's Avatar
here try this link external to internal voltage reg. converison
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-04-2008, 11:29 PM   #10
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by truckdude239 View Post
So, my 71 does not have a regulator, it had a alternator with a internal regulator on it. So my question now is, i have the new alternator with 3 wires. One post, and then two wires on a plug on the top. Where do those three go??? One is labelled battery and is pretty obvious. Then there are the other two wires. A thick red wire and another thinner wire.... Any help??
Old 08-05-2008, 10:12 AM   #11
VetteVet
Msgt USAF Ret
VetteVet's Avatar
http://www.6066gmcguy.org/charging.htm
VetteVet
