What a surprise!
Well I started to do a little sanding on top of the cab today, and they were a huge crack, just above the passenger side door. I put a screwdriver in the crack and lifted up a hand sized piece of bondo about 3/4 of an inch thick. Whoever done this they were very good with bondo because they put the seam back in the top of the cab. That then revealed a pretty good size dent that I don't know what to do with since I can't hammer it out. I'll post pictures of the dent tomorrow. but the picture below shows how it looked
Mitch 22yrs. Young 1970 GMC Short-Step 350/TH350 Combo. . ![]() Current Project 68 Gmc "Second Chance" Go to my 68 GMC Shorty Rebuild Thread http://67-72chevytrucks.com/vboard/s...39#post6341739 Last edited by mas09ts; 08-04-2008 at 12:02 AM. |
its all about the +6 inches
Re: What a surprise!
you could always fill it in with 3/4 inch of bondo.
![]() Join Date: Sep 2007
dent puller my friend
1967custom |
Old Skool Club
![]() Join Date: Jun 2001
There are "pick" type of tools that you would use by drilling a 1/8-inch hole or a series of holes then use the picks to pull the metal. They're called pull rods.
Another method would be to use one of the mig/tig/arc tools that would have you welding a stick to the metal, then using a puller (slap hammer) to pull out the dent. Or, as LonghornMan said......
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
stud welder would be my choice ... no holes to fill afterwards.
Never Ending Projects
X2
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
![]() Join Date: Feb 2001
I have been very lucky. They just took the bed off the frame and the only rust of concern is the rockers on both sides. Otherwise it is only surface rust. No doubt the Tn. climate is much kinder to our trucks than the midwest. With these old trucks you never know what one will find under the paint.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
stud gun...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
to save a few bucks, use flat washers tacked to the low spot of the dent stand the washer on end. then take a regular dent puller and put a long 3" metal screw in place of the screw, bend the long screw into the shape of a j and use that instead. then go back with a cut off wheel cut the weld tack and grin smooth.
Mike K Friend of Bill W |
#10 | |
Gettin By on Gettin By
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" |
Old Skool Club
...but I betcha won't do it but once!
yeah, i won't let it get more more then once, unlike snipe huntin.
I'm going to do it this week. Damn good idea. Will get some pics. *trying not to hijack post*
#13 |
I have a radical idea!
Agreed! I love my stud welder!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#14 |
Thanks for all the help guys, I wasn't able to take any pics of the dent today. But I will tomorrow morning. Got a cab corner and rocker panel welded in though so. . .
Mitch 22yrs. Young 1970 GMC Short-Step 350/TH350 Combo. . ![]() Current Project 68 Gmc "Second Chance" Go to my 68 GMC Shorty Rebuild Thread http://67-72chevytrucks.com/vboard/s...39#post6341739 |
#15 |
#16 |
Ouch.... that hurts!!!!
I would try the washer/slide hammer idea. Stud welders are great, if you have one, but that washer idea is GENIUS!!!! |
#17 |
that'll buff out....
