12 bolt rear disc brakes.
I was wondering if any one had ever tried to assemble a rear disc brake kit using 10 bolt factory discs? I blew apart the rear end on my 01 Silverado (again!), and was removing the wheels, and the factory set up is very straight forward. I was wondering if the ends of the 99+ 10 bolts are the same as the 63+ 12 bolt axles.
Re: 12 bolt rear disc brakes.
I found this the other day for a local buddy. http://www.jawsgear.net/moser/catalog/forms/form1.htm
Hope this helps.
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 Last edited by 64c20crewcab; 08-04-2008 at 12:45 AM. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I've done disc's on a 5 on 5 12 bolt. Is yours 6 on 5 1/2 or 5 on 5? I've looked at the rotors on the light duty 3/4 ton's in the ~2002-2004 years, but haven't done anything with it yet.
![]() Join Date: Aug 2005
Here's mine using 3rd gen f-body calipers, caprice rotors, and Glock's brackets (member here). More info around pages 22-24 of my tahoe build:
![]() ![]() Last edited by Frizzle Fry; 08-05-2008 at 02:00 AM. |
