08-04-2008, 03:29 AM | #1 |
LS swap guys inside please
OK,....I rounded up a 2000 4.8 for my 67 C20 4x4 and I am going to be pulling the motor, harnes and trans out in the next week.
So those of you that have done the swap please post up pic's, links, tips tricks etc! I have not decided if I want to put in the TH350/205 that I have sitting here or if I want to track down the pieces I need and put the 4L60 and a transfer from something newer in. Please advise, Mike |
08-04-2008, 06:56 AM | #2 |
Always wrenching!!
Re: LS swap guys inside please
Mike just come over and look at my truck, might be diff since mines a 2wd.
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
08-04-2008, 08:46 AM | #3 |
here are a couple...
http://67-72chevytrucks.com/vboard/s...d.php?t=244448 http://67-72chevytrucks.com/vboard/s...d.php?t=195643
R.I.P. Killer 71 10/26/07 |
08-04-2008, 11:10 AM | #4 |
http://www.ls1tech.com/forums/showthread.php?t=947786
We are still adding to the thread so check back. |
08-04-2008, 02:58 PM | #5 |
ROCKWELL 5 TON CLUB !!
i have had bad luck with 4l60e's,would be a lot easier and less $ to go with the 350/205 combo.more dependable IMO.
i am wrapping up my swap now, "shifty" on here and on ls1 tech has got some great info in his build,plus TONS of pics. ls1 tech is a good resource. you can look at mine,not a lot of photos,anything i can help with,just ask good luck. andy
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!" MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=221935 1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS HINT:NEW NAME "K5ontheROCKS!" |
08-04-2008, 03:01 PM | #6 |
PROJECT 7DEUCE
I would also advise you to get with shifty and pick his brain..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-05-2008, 03:18 PM | #7 |
Questionable
Just click on the link in my signature and spend the next couple of days clicking through to people's projects. (the link @ LS1tech). It links back to projects at this forum and others.
i could sit here and retype everything you'll find there and try to condense it, make it really nice for you ... i am a nice guy and all ... but i'm not that nice good luck with your project!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
