08-04-2008, 12:55 PM | #1 |
Georgia Boy
700R4 questions
What kind of money am I looking at in rebuilding the 700 I have in my truck now? If I have it built back to stock specs, will it handle the 300hp I have now or the 400+ I plan on having later? Is it expensive to get a stall converter for these things, or will it be a huge waste of time and money? Anyone have experience with this?
08-04-2008, 03:32 PM | #2 |
Parts and more parts
Re: 700R4 questions
A 700 R4 will cost you what you want to spend. I have a couple that I have built for different trucks (one with a 2400 Stall converter and NO LOCK UP) and the other with a lockup convertor and a stock stall. I have put the heaviest items that are available to the public in both of them. This allows for a good chrisp shift in both trannys and longevity in the parts. My NON-Lockup tranny is behind a 425 plus HP 383 stroker and is pushing 3.73 gears. The tranny with a lock-up convertor is behind a 91 stock 350 engine with upgraded exhasut and air intake at around 190 HP and 3.42 gears. I stand by the fact that the heavier duty parts will make the tranny last longer, but I would do a standard 350 the same way. Both trannys that I have done ran me around $1800.00 to build and I already owned them.
08-06-2008, 02:47 PM | #3 |
Squarebody Aficionado
Re: 700R4 questions
i just re-did the tranny in my truck and it only cost me 700 bucks, the 355 in my truck is making about 350-400 hp and i put a 2300-2500 stall converter i bought for another $250. I think if you only want to do it once have the guy build your tranny to the power you expect to have not what you have now, no reason to do it twice.
08-06-2008, 09:44 PM | #4 |
Re: 700R4 questions
on the non lock-up you dont have od correct?
08-07-2008, 08:15 PM | #5 |
Re: 700R4 questions
08-24-2008, 02:16 PM | #6 |
Navy Radioman Veteran
Re: 700R4 questions
Here's a different question:
The 700 I have in my '87 SWB is now behind a mild 454 instead of the 350 that it came with.. In order to get the linkage correct after all of the aftermarket additions to the BBC, I put a Lokar system in place for the throttle and TV. I followed the instruction for the TV cable which were to make sure the tv cable was stretched to its maximum at WOT. But, yet the shifting is still late and it drops out of od on any kind of load. I'm sure it's an adjustment issue but is it something that I'll just need to play with until I get it right or does it need to be done professionally? I've debated rebuilding the TH400 that came with the 454, but I like the idea of having the 700 out there for cruizing to various areas in the region. Thanks!! Kenny
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside |
08-24-2008, 03:04 PM | #7 |
Georgia Boy
Re: 700R4 questions
Well, I finally sold my 4x4 and I'm going to pick up another 700 for my baby tomorrow. Does anyone have a link to the instructions on how to adjust the TV cable correctly? I don't want to have to go through this mess again in a week!
08-24-2008, 03:04 PM | #8 |
Workaholic
Re: 700R4 questions
If you don't get this issue fixed ASAP you will burn up the tranny. . .
1979 K-10 Silverado (work in progress) 1991 V1500 Subruban 1999 Suburban LT 4x4 2006 Suburban LTZ (daily driver) |
08-24-2008, 04:38 PM | #9 | |
Re: 700R4 questions
Some of the articles talk about using a pressure gauge to assist in the adjustment.. which leads me to think might as well have someone who knows transmissions do it. On the other hand, common sense tells me that small adjustments to the cable should get me there too. I do know the way it is, the trans won't last long especially hitting it with almost 500 ft lbs. Kenny
08-24-2008, 05:10 PM | #10 |
Re: 700R4 questions
Did the kit come with a geometry correction kit that bolts to the carb linkage ? The kickdown hole provides incorrect geometry for TV purposes.
1977 GMC Sierra Grande |
08-24-2008, 05:53 PM | #11 | |
Re: 700R4 questions
I basically got the HI-tech throttle linkage kit wbracket to bolt to the back stud of the carb and the Hi-Tech kickdown cable that bolted to the same bracket. It had a stud that bolted to the linkage of the Edelbrock 750 I'm running... The dealer said nothing about a linkage bracket to correct the geometry. I know the bracket you're talking about, but i'm not using it now. Kenny
08-25-2008, 01:54 AM | #12 |
Re: 700R4 questions
You need something along the lines of this. http://www.tvmadeez.com/1406_cam/
08-25-2008, 07:33 AM | #13 |
Re: 700R4 questions
Thanks!
I 'll check it out. Kenny
08-25-2008, 07:34 AM | #14 | |
Re: 700R4 questions
08-25-2008, 02:48 PM | #15 |
BAD BOW-Silverado XST
Re: 700R4 questions
http://www.700raptor.com/ My rebuild it between a Level 3 and 4. Works great. Shifts are awsome. $1700 + on rebuild!! |
08-26-2008, 07:44 PM | #16 |
Re: 700R4 questions
ok.. I decided to have the TH400 rebuilt.. too much powah for the 700.
Dropped it off yesterday, stopped by today, 700 already out, TH400 getting rebuilt, drive shaft off to the driveline shop. Should be back on the road by the weekend. Kenny
08-26-2008, 07:48 PM | #17 |
Re: 700R4 questions
what you doing with the 700 ????
08-26-2008, 08:03 PM | #18 |
Re: 700R4 questions
hi neighbor... no plans yet.
Thinking of keeping it for my next project... but, now that I think of it, that project will have a 496 or better in it so it would shred it anyway. Kenny
08-26-2008, 08:09 PM | #19 |
Re: 700R4 questions
i need a deal on one if you decide to not use it
08-26-2008, 09:09 PM | #20 |
Re: 700R4 questions
I might be able to hook u up.
Ken
08-26-2008, 09:12 PM | #21 |
Re: 700R4 questions
08-30-2008, 06:44 PM | #22 |
Re: 700R4 questions
I'm in Fla right now but... it's yours if you're interested.
PM me for additional. Thanks! Kenny
08-30-2008, 06:50 PM | #23 |
Re: 700R4 questions
08-30-2008, 07:47 PM | #24 |
Wishin' I had more money!
Re: 700R4 questions
