Old 08-04-2008, 04:29 PM   #1
'72_GMC
'72_GMC's Avatar
looking for a Guru; Transmission Swap
I came here looking for a Guru; Transmission Swap
Last week I got lucky, I found a '72 GMC BB Camper Special, it has a New 402 BB, a New Turbo 400, with all new supporting accessories, New Radiator, New Carburetor, All new Brakes, even new Brake lines, New tires, New Tail Gate, Even a new WW wiper motor, Not a Dent, One rusty Rocker panel, Just a Real nice truck, Somebody Traded it in at the Ford Dealership and when I heard the Price, I bought it without even starting it, they said they didn't have the key and one look at the shiny new Big Block and I didn't care. I went inside and payed for it.
Coming back out to see what I had bought, the Manager guy said I could start it with a Screw Driver. Some assistant manager followed me back to the truck with 2 Screw Drivers Cool! I stuck one in the ignition switch and turned, the whole lock Turned, and turned, and turned some more, after about 3 revolutions I reached up behind the dash to stop it turning, fearing for the wiring harness and................ Uh, Oh, no worries, Looking to confirm, There is no Wiring harness, Not a piece of wire in the whole truck! Ahhhhhhhhh
I went home and got my Van and Towbar, Towed it home
Well I have this '71 1 Ton 3500 Flat bed 4 Sp parts truck out back behind the house, I was always going to fix that, it's a little Moss covered and Rusty but it had the 4 sp and I like that, anyway for about 3 days I pulled the wiring harness out of it and put it in the new and much more beautiful '72, Cool, Works Great, Except the Reverse light wiring is too short, and no Transmission down shift circuits, OH! No neutral safety switch either, careful.............
The Dilemma; to, Repair the wiring harness with the addition of some small circuits or keep swapping stuff over from the other truck. I like the manual Gear. Problem is, and this is my Question, it looks like the BB is longer then the small block, it looks like it is mounted, or allowed to Extend further back in the truck, The 4 sp Truck is a small block, It Appears, if I mounted the Crossmember to the frame, and the Bellhousing to the Motor, it appears the motormounts would not line up, it looks like they would be too far back in the truck.
My Guru question, does the BB trucks have the same Crossmember?
Is it the same for a 3/4 ton as a 1 Ton?
And Just in case the rest works out, Can I use the flywheel from the 350 on the 402?
1964 Pontiac GTO Convertible
1964 Pontiac Catalina 2 + 2 Convertible
1962 Pontiac Bonneville Convertible
1966 Buick Skylark GS Convertible
1962 Skylark Baby GS
1959 Chevy 1 Ton Long Box PU
'72_GMC is offline   Reply With Quote
Old 08-04-2008, 04:54 PM   #2
Green Machine
Green Machine's Avatar
Re: looking for a Guru; Transmission Swap
As far as the wiring, check the parts board, register if you want to post a want to buy thread. Get a harness that matches your equipment, gauges, auto trans, no AC that type of thing. Good used unmodified under dash harness would be the the best and they are usually priced reasonable too.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-04-2008, 05:15 PM   #3
'72_GMC
'72_GMC's Avatar
Thanks Green Machine :-) The more I think about it, the more I like a Stick, That T400 Is brand new, love to trade it for a NV4500 5 SPEED or Comparable.
