08-04-2008, 05:12 PM | #1 |
Pics and progress on my 86'
So I finally got the factory x-member out, really psyched about it. Well I guess I should have posted it on another thread, but I also had some questions for you guys with a dropmember; will I have to reroute all the gas lines when I go to cut for the R&P notches and brake lines? I'm not a mechanic by any means but I'm very mechanically inclined and have had another bagged truck before but this is my fisrt time w/ the DRMBR so any help would be appreciated. Also I only got $200 plus the cost of the DRMB....SO FAR. don't hold back on any comments and or questions....
Whoever said this was easy to install this,b^$#s*&t......
GROUND ZERO IS R LIMIT |
08-04-2008, 06:11 PM | #2 |
Re: Pics and progress on my 86'
im no mechanical genious either but i would be willing try to help you out and maybe learn some stuff too so i can lay out mine.
08-04-2008, 06:51 PM | #3 |
hey(spr85gmc),thats cool man, you're more than welcome to come by anytime and check out the progress I will send you a private mess. w/ my address & phone#. L8terz.......
08-04-2008, 07:39 PM | #4 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-04-2008 at 07:39 PM. |
08-04-2008, 11:45 PM | #5 |
more more keep us up dated!! looken good
lifes short fabricate as much as you can! |
