08-04-2008, 07:47 PM | #1 |
Visor brackets
Has anyone replaced their visor brackets only? My sun visors are in good shape, but the mounting bracket on the driver's side is broken, and the passenger side is cracked. I removed the driver's side visor to see how difficult it would be to replace the bracket with a replacement like the one from Brothers, but I can't see how to seperate the visor from the bracket.
http://www.brotherstrucks.com/prodin...number=BRKT072 |
08-04-2008, 08:15 PM | #2 |
Nothing to see here.....
Re: Visor brackets
the old visor bracket and rod must be pulled straight out of the visor body. it's a pain, believe me!
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
08-04-2008, 08:24 PM | #3 |
Re: Visor brackets
I believe you! I pulled hard on it and it didn't seem to budge.
08-04-2008, 08:41 PM | #4 |
Re: Visor brackets
yes, they are a bugger to get seperated! I think they had a glue of some sort applied at the factory that made them not droop over the years.
try a twisting motion while pulling hard...... uh, I mean the visor bracket...
08-04-2008, 10:15 PM | #5 |
Re: Visor brackets
08-05-2008, 07:43 PM | #6 |
67-72 Addict!
Re: Visor brackets
The way I seperate them is to drop a few drops of "3 in 1" oil into the rods then start twisting them back and forth. They will come out after a few minutes of hard twisting There is a split sleeve inside the visor that the rod slides into.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
