08-04-2008, 11:07 PM | #1 |
Old member
Finally installed
OK,
I know what your going to say they don't look right and your correct they don't. They don't make a kit for our trucks so I guessed at the kit I needed and then ordered some more rubber bushings also that where thicker. I think I need to shave some of it off to make a better fit. I cut about a 1" off the bottom bolt so it wouldn't poke a hole in the bottom of the bag also. Haven't drove it yet since I just finished it up to this point tonight. I ran 2 seperate lines for them so I want have the pressure swaping from side to side. I ran each line back through the frame rail then used the 2 air valves to mount my tag. First is with caps on: Next with them off:
08-04-2008, 11:26 PM | #2 |
67-72 parts collector,…
Re: Finally installed
Any reason why you didn't just run a bag by itself? (without the factory rear spring) There are plenty of people on here running a pair of Slam Specialties RE-7's on schrader valves with good results. Just curious.
08-04-2008, 11:31 PM | #3 |
like lolife said, the bags are meant to be run without springs. that's the point
08-05-2008, 12:25 AM | #4 | |
The ones he used are helper bags that go inside of a coil. Seems like it would be easier to just swap the coils for bags..... but there's usually more than one right way to get things done.
08-05-2008, 05:35 AM | #5 |
Old member
I needed the air bags to help with it bottoming out. Yes I guess I could have gone with just a air bag rear but I have very limited knowlege of doing all that. This was easy no mods and I didn't have to make any brackets are anything to hold them on with.
It was cheap also,less than $150.00 for everything. I wish it was bagged all the way around though. Maybe one day!
08-05-2008, 07:04 AM | #6 |
67-72 Addict!
I don't know jack about bags but the air valves are cool
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
08-05-2008, 08:19 AM | #7 | |
Old member
70c10 Re:
Thanks I almost didn't do them. I was going to leave it behind the bumper. I think it looks cool too!
