Old 08-05-2008, 09:55 AM   #1
bigdon-70blazer
Flaring stainless steel brake lines
I bought stainless brake lines from inline tube and they were pretty good as far as fit but they were too long in the back by 5 inches, so I thought I would by a flaring tool and double flare the line and re-bend it. It seems that I can't get the line to hold in the flaring block I got and I can't get a flare. Is this because I bought a cheap tool? Are the more expensive tools better able to handle this job? Help!
bigdon-70blazer is offline   Reply With Quote
Old 08-05-2008, 10:39 AM   #2
FormerMember
Re: Flaring stainless steel brake lines
The tube they use is very hard... You can use a better tool, like a Mastercool hydraulic flaring press, but that would cost more than the set of lines you bought.
FormerMember is offline   Reply With Quote
Old 08-05-2008, 12:53 PM   #3
Willy Prost
As you have found out, stainless is much harder to flare than "regular" steel.
That is why stainless tubing only uses a single 37 degree flare.
That means another tubing flaring tool that does 37 degree flares.
Polished stainless sure does look pretty, though.
Willy Prost is offline   Reply With Quote
Old 08-05-2008, 12:55 PM   #4
FormerMember
The tubing he has is 45 degree double flared.
I use stainless annealed tubing from Summit and double flare it.
Old 08-05-2008, 01:07 PM   #5
Riveted1
Tasty Cakes!
Riveted1's Avatar
What kind of flaring tool did you get? Inline Tube sells ones for SS lines.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 08-05-2008, 01:13 PM   #6
FormerMember
They sell these:
http://cgi.ebay.com/ebaymotors/Maste....c0.m245.l1318
Old 08-05-2008, 01:59 PM   #7
tcb-1
Nothing to see here.....
tcb-1's Avatar
hummm, I remember this conversation somehow??
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 08-05-2008, 04:42 PM   #8
Green Machine
Green Machine's Avatar
Clamp that block in a vise, sometimes that extra pressure will hold it. Also I tighten the bolt on the block nearest the tube first, then tighten the far nut, get more leverage that way.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-05-2008, 06:00 PM   #9
cparman
sharp as a marble
I agree with green machine. I have a MATCO brand double flare kit, and flaring the lines on my 67 Chevelle were a bear. IF you have a vise, and tighten the mess out of the clamp, it will work. I have a friend that just bought one of those hydraulic tools and he says it is the stuff.
cparman is offline   Reply With Quote
Old 08-05-2008, 06:06 PM   #10
71BB_LWB
Thread Killer!
71BB_LWB's Avatar
I also use WD40 to lube the line while flaring. I have a Summit Racing flaring tool and I clamp it in the vise like stated before.
71 Cheyenne SWB LS1 and auto.
http://67-72chevytrucks.com/vboard/s...d.php?t=256470
_____________________________________
If it's worth doing, it's worth doing twice...
Don't Mistake Honesty for Negativity...
71BB_LWB is offline   Reply With Quote
