Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 08-05-2008, 11:46 AM   #1
el greco
1962 C-10 Positrac Rearend Complete $200.00
'62 Chevrolet rearend from a C-10. If I remember correctly, this is an Eaton model number H-033. This is the unit with the dropout carrier like a Ford 9". It is has Posi-Trac, 3.90 gear ratio, 6 lug on 5.5".
Comes complete with brake drums, wheel cylinders, brake lines, and all brake hardware.
In case any one doubts it, yes this is a positrac. It has clutch pacs. The axles are slightly different than the non-posi ones in that the end of the axles, past the C-clip grove, are slightly longer. Also, the pin that goes between the axles is a smaller diameter on the posi units.
Also, included are two 15X10 steel wheels in ok shape and worn out tires. The tires are no good for the road, but can be used to move the axle around. Center caps, but no lug nuts. Uses common 7/16" conical seat lug nuts.
Please email cj3a1951@hotmail.com.
Tony
el greco is offline   Reply With Quote
