![]() Join Date: Sep 2004
Anyone had their rearend rebuilt?
Curious as to how much you spent just got a quote to drive my blazer in and get new gears seals and bearings installed for 650. 1 day of work. Just curious if this sounds right or not? Thanks
![]() Join Date: Nov 2007
Re: Anyone had their rearend rebuilt?
If they're rebuilding the entire axle (hub seals, spindle bearings, new gears, master install kit, and labor), that may not be too bad. If it's just the pumpkin (new gears, master install kit, and labor) you should be closer to $500 an axle.
Check around the net and with the vendors. It may be a bit cheaper to buy the gears and install kit you need and then just pay the labor to install it. |
I've spent about $350-400 just on gears, seals, and install kit by the time it is shipped here; that's just parts. So that's not too far off when you add a couple hours of labor to it. Plus, you would rather pay somebody a little more if they know what they're doing. If just any ole shop does it & not experienced, you'll have alot of noise & replacing them again soon!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
If your taking to a shop, flat rate time is about 5-6 hrs. plus parts. Around here you'ld be paying about $1200.
Old School, New Style
Sounds like a good price IF they know what they are doing.
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
I'm a poor spectator
Is this for both rear and front??? Or just rear?? If it's both then someone is messing up their calculations cuz that's dirt cheap, if it's for one, it's about right.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
I just had mine done about 3 weeks ago, I paid $550 just for labor. I had another $930 into .488's front and rear (Yukon gear), Auburn Pro series posi (rear only), and master install kits, lube, & additive. Oh, and a u-joint for the front axle.
This is just the rear and my pinion seal is leaking so I am thinking of changing to some different geas so the price includes all the parts involved to switch out gears ,bearing and seals. I drive it to them and I drive out the same night. 650. They are a well respected rear end only specialist type of shop here in the bay area. So I think 373 gears is what I am gonna do.
$650 isn't bad, the axle bearings/seals are an easy do it yourself if it isn't included in the $650 price. Do you know what your current gear ratio is, and do you have a 3-speed or OD trans? The reason I ask is that a 3:08 is kind high, but a 700r4 has a low first gear and then a 3:08 is OK. If you have a 3:73 already and a 3-speed (th350/400) then a little higher gear will help cruize rpm down. And if a 33, 35" tall tire it all changes again?!
No i have a turbo 400. Im running those 22 285 40, I am thinking of a 373 gear set to pick up some tourque
Let me go find the tire size calculator I have, figures tire height and the "gear ratio after tire height. Sorry about asking again, didn't realize I was posting to the same member I did a few days ago, I know the Blazer, just forgot!? I'll be right back with a guesstimate, BTW width of wheel (can make tire a bit taller or shorter depending on width).
http://www.dirtroad.com/gears.htm
This link is sweet!! Has calculators for just about everything!! You need to know what your OE gear is and then maybe a guess at an OE tire size? Then it'll pop out the gear ratio needed to restore OE ratio. Figure a steeper ratio if you want more perf. I'll keep looking to see if I can find the one that shows your actual gear ratio + tire size = the acts like gear ratio. http://www.intercotire.com/site63.php OK this one is a table, but it helps, 31" tall tire needs this ratio for a good 65 mph, cruise, this one for in town, and this one for perf. Hope that helps?? Last edited by 70rs/ss; 08-06-2008 at 03:06 PM. |
#13 |
Sweet damn that was helpful right on man
#14 |
Glad it worked. Is there a way to put these links into a sticky or something? Not mine, nor am I trying to take credit for them, but the info is pretty good and I am sure members could use it??
