Old 08-05-2008, 04:52 PM   #1
bkwagonss
Junior Member
bkwagonss's Avatar
Part name?
Does anyone know what this part is called.
I can't find it in anyone's catalogs.
It's the backing piece down at the end of the A-pillar.
As you can see mine are pretty bad.
1971 Short Stepside,(sold)
2011 Caprice PPV
1950 Chevy Fleetline
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=302759
bkwagonss is offline   Reply With Quote
Old 08-05-2008, 04:58 PM   #2
tphsmith
still buypickupparts
tphsmith's Avatar
Re: Part name?
if its at the bottom of the cab where the cab bolt connects the front fender, i see LMC calls it the Front pillar repair
Its Gonna be a Great Day, I woke up this Morning.
72 SWB Fleetside freshly painted. putting a 94 LT1 with
700R4 tranny lowered 4 in the front 6 in the back
81 chevy half ton 350
89 Silverado 4x4 going ta church truck
tphsmith is offline   Reply With Quote
Old 08-05-2008, 05:09 PM   #3
bkwagonss
Junior Member
bkwagonss's Avatar
Re: Part name?
Thanks, but no not the A-pillar repair stamped sheet metal panel. This piece goes in behind that and it's thicker metal.
2011 Caprice PPV
Old 08-06-2008, 08:21 AM   #4
bkwagonss
Junior Member
bkwagonss's Avatar
Re: Part name?
I'm going to Carlisle on Saturday.
Guess I'll just bring this with me and see if anyone sells them.
Maybe someone will have a used set in better shape than mine.
2011 Caprice PPV
Old 08-06-2008, 08:47 AM   #5
dakman
Re: Part name?
could they be shims from the factory when everything was lined up?
dakman is offline   Reply With Quote
Old 08-06-2008, 09:31 AM   #6
bkwagonss
Junior Member
bkwagonss's Avatar
Re: Part name?
Maybe, but more than likely it is used like a washer.
As everyone probably knows, there are 4 bolts that go through the A-pillar, then the kick panel, then the floor (or inner rocker), then the floor support.
This piece was the last thing the bolts went through before the nut on the back.
Maybe I don't even need them and just use washers.
2011 Caprice PPV
Old 08-06-2008, 01:25 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Part name?
..and you can't just "fix" it and re-use it?
Member Nr. 2770
Old 08-06-2008, 02:16 PM   #8
haysonj
haysonj's Avatar
Re: Part name?
In my assembly manual they show it as part of the hinge pillar which I assume you are calling the A pillar. They don"t have a name attached to it.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 08-06-2008, 02:30 PM   #9
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Part name?
Its called a little round metal thingamabobber
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
