anyone know brake system fluid capacity?
I need to fill/bleed entire (probably 95% dry) system on my short bed 66 C10-
I have front disc/rear drum master and proportioning valve from an 83 - mounted on the front of frame like the 83, new rear wheel cylinders and mostly new steel lines. 3 or 4 quarts do it? |
![]() Join Date: Sep 2006
Re: anyone know brake system fluid capacity?
One should do it... but I would have another just in case. I have never used more then a quart for a whole system.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 08-05-2008 at 10:33 PM. |
Same here. One bottle is typically more than enough but it always pays to have an extra on hand incase you loose alot of fluid trying to get it bled out.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 Last edited by HotRodYJ; 08-06-2008 at 06:57 AM. |
Good deal - thanks, guys
