Old 08-05-2008, 09:10 PM   #1
blazer72
Freedom isn't Free
blazer72's Avatar
Manual to Power Brake Conversion
OK - I'm sure this has been asked a couple times, but other than parts, what's required (modification-wise) to convert manual brakes to power brakes.
blazer72 is offline   Reply With Quote
Old 08-05-2008, 09:35 PM   #2
69TowRig
Re: Manual to Power Brake Conversion
It's all just parts swapping really. You may need to make new hard lines from the proportioning valve to the lines on the frame but other than that it's a bolt-in. I converted mine from manual drum/drum to power disc/drum when I did mine, but since yours is a '72 you have the hard part covered already.
What you will find is that any junkyard parts you can find will probably be leaking, both the MC and the booster. I bought a setup off of ebay, the MC was shot but the booster was still good. I put a rebuilt MC from the auto parts store on it and have enjoyed good brakes since then.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 08-06-2008, 12:11 AM   #3
GMCMAX
Active Member
GMCMAX's Avatar
Pic of install
http://67-72chevytrucks.com/vboard/s...d.php?t=221598
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 08-06-2008, 04:42 PM   #4
blazer72
Freedom isn't Free
blazer72's Avatar
You guys are awesome - thanks a ton!!!
Previous rides: (worth mentioning)
67 camaro
70 long fleet, 69 short step (stolen), 72 blazer
62 chrysler imperial (hell yeah)
55 and 56 chevy hdtps
72 monte carlo
Daily Driver:
86 S-10 Blazer (drive it til I die) and 71 long fleet
Projects:
71 suburban, 72 C-30 Dually, 71 Chevy LWB
