Old 11-13-2002, 10:19 PM   #1
kroodawg
Electric Fans
Has anyone put any electric fans on there trucks?
How well do they work? Do you have any pics?
My truck
http://members.cox.net/ken1173/P9030017.JPG
kroodawg is offline   Reply With Quote
Old 11-13-2002, 10:50 PM   #2
Truckstr
Truckstr's Avatar
I have an electric fan on my '67 (presently a mild 350). It has a Griffin 4 core aluminum radiator. The electric fan works great. It's a"pull type" (set up behind the radiator) on an adjustable thermostat. Works great! I don't have pictures, but I'm not done tucking the wiring away anyway - so it's not "pretty".
I'm sure somebody else here has one with pictures. Don't be intimidated. It's not that big of a deal.
Jeff
'67 short Fleet; my ongoing project.
'66 long Fleet; my original "baby."
Live life or bust trying.
Truckstr is offline   Reply With Quote
Old 11-13-2002, 11:02 PM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I have the set we designed on my K-5 Blazer and they work great. Here is a link to them on our website.:
http://www.classicheartbeat.com/new_products.htm
If you click on the discription for them it brings up pictures. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 11-13-2002, 11:09 PM   #4
70 Suburban
Rods
the fans
I put an aluminum rad from a 89 pontiac firebird and the dual fans i gained hp and beter trafic cooling..ill get the pics asap but they all mont up just like they did in the car.
70 Suburban is offline   Reply With Quote
Old 11-14-2002, 12:12 AM   #5
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Here's a pic of Wes's dual electric fans with a stainless steel shroud installed on my 69, and they work great.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 11-14-2002, 01:39 AM   #6
Ron's68
Ron's68's Avatar
Hay Blazerman. I wish I had that much room between my engine and fan. Are your motor mounts in the stock location. Mabey mine has been moved. I dont have much room between my engine and radiator. Im trying to fit a fan now out of a mid 90's camaro. Its only 6'' deep and I have to move it to one side of the radiator or the other. It will not fit in the middle, hits the water pump pulley. I'm thinking about putting it in front of radiator. Mabey I'll look for a smaller one.
68 LWB, .040 over 350 with 10:1 pistons, balanced, vortec heads,comp 270H cam, air gap RPM manifold, holley 750, 4.10 posi and gear drive to annoy the neighbors.
Ron's68 is offline   Reply With Quote
Old 11-14-2002, 12:19 PM   #7
Classic Heartbeat
His truck is a 4x4 Blazer. The engines are mounted in the 6 cylender possition, that is about 2" behind the V-8 possition. You should have plenty of room for the fan shroud and assembly unless someone installed a long water pump. The high point of the duel 12" fans is not in the center where your water pump is located. They are to the left and right of it. WES www.ClassicHeartbeat.com
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 11-14-2002, 12:57 PM   #8
crazy longhorn
Fabricate till you "puke"
I havent been into the 4x4 trucks, but on the 2wd trucks mounting the v8 on 6 /250 stands gives right at 3 1/2" set back from factory v8(smallblock) position......
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-14-2002, 01:54 PM   #9
kroodawg
Hey Blazerman I like the looks of that. Where ya get it.
I know I want to go with SS.
Old 11-14-2002, 04:54 PM   #10
Classic Heartbeat
kroodawg, That is a fan shroud and assembly that I designed. We have them in the new products section of our website. Here is the link if you are interested: http://www.classicheartbeat.com/new_products.htm
It is the last part listed on that page. WES www.ClassicHeartbeat.com
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 11-14-2002, 06:24 PM   #11
kroodawg
Thanks Wes will have to get me one.
Old 11-15-2002, 01:40 AM   #12
Ron's68
Ron's68's Avatar
Thanks for the info WES, I do have a long water pump on my truck. I'm thinking about putting the fan in front of the radiator. It looks like theres enuff room between the a/c evaporator and the radiator. Has anyone done this? Will it still cool like it should? Just a thought. It would really clean up the front of my engine.
Old 11-15-2002, 05:41 AM   #13
Lippyp
English Chevy Owner
Lippyp's Avatar
Make sure that you get a fan that is designed to be a "pusher" rather than a "Puller" if you want to put it in front of the rad. Fans work great in the direction that they were designed to work in, if you just reverse the polarity so they spin in the other direction you will not move nearly as much air due to the shape of the blades. Some aftermarket fans are designed so that you can turn the fan blades around and convert them from push to pull. Other than that I don't see why it wouldn't work.
The only fan on my truck is a smallish electric puller that the previous owner installed (Came of a Japanese car!) haven't had any overheating problems yet but I may sort it out better in the future. (It ain't hot very often over here!)
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 11-15-2002, 07:04 AM   #14
Ron's68
Ron's68's Avatar
Thanks Phil, Is your truck popular in the U.K.?
Old 11-15-2002, 02:44 PM   #15
Lippyp
English Chevy Owner
Lippyp's Avatar
I know directly of two other 67-72's in the UK and saw a third in the classifieds section of a specialist mag recently, all three are stepsides. I know one of the other guys does visit this board regularly. I'm sure that there must be others but I have only had mine for a year and so have only made it to a couple of shows/cruises.
You tend to see more earlier trucks over here, 40's to early 60's and later 70's to current. I even saw a barn fresh running 1917 REO for sale at a show recently. It seems that the late sixties/early seventies trucks are a bit neglected at the moment, good for me though as I paid a good price for mine.
Everybody that sees her does tend to fall for her though, I still have a big S**t eating grin on my face when I drive her through town and everybody stops and looks. Maybe it's on account of her being bright yellow and a little loud!
Phil
'67 C10 long fleet.
