08-05-2008, 11:36 PM | #1 |
Questionable
plasma cutter questions
so, while working on my frame, i can't tell you how many times i've told myself..."damn, i could really use a plasma cutter". i've even said it about things around the house.
i gotta ask: if you are only going to use your plasma cutter a couple dozen times, do you really need to spend 4x as much on a name brand, or can you just buy a "decent enough" import brand that has a "generally acceptable" quality rating? i ask, because i started looking around. it's tough to get a 220v cutter for less than $1k. i found these Hobart 110v refurb units for $600 shipped: http://cgi.ebay.com/HOBART-AIRFORCE-...QQcmdZViewItem i found these imported units (that actually use good name-brand MOSFETs) for around $400 shipped: http://cgi.ebay.com/EVERLAST-CUT50D-...QQcmdZViewItem (there are a couple from this seller) i am curious to get feedback from you guys and gals because, well, i trust your opinion. literally - i am only going to use it to cut on my frame, which is what, 3/16" mild steel?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 08-05-2008 at 11:37 PM. |
08-06-2008, 06:02 AM | #2 |
and a few others
Re: plasma cutter questions
Bump for ya
I'm curious too
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
08-06-2008, 06:37 AM | #3 |
Dirteh Kitteh
The weakest link in the import (cheaper) models are the tips. Change it out for a quality one and you'll probably never notice the difference.
Darrin 1955 Willys CJ-5 all original and the oldest CJ-5 on the road. 2001 Dodge Neon (wife's car) 1995 Jeep Grand Cherokee Limited Edition SOLD 1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD 1993 S-10 4X4 Tahoe SOLD Sign up with the Contact List RIP ESLL |
08-06-2008, 08:27 AM | #4 |
I have an import (Italian) plasma and it works great ... purchased it off ebay about 8-9 years ago and it's still going strong. It cost me approx $600-$650 shipped. Mine will cut up to 3/8" - 5/16" thick which is plenty for my needs.
my one bit of advice is MAKE SURE your air is clean and dry and like Mickey already stated, use good consumables and you should be fine. |
08-06-2008, 01:29 PM | #5 |
Questionable
what are "quality" tips? is there a brand you would recommend? i know nothing about plasma cutting.
it sounds like you use gas (a tank) with this that has oxygen or another gas in it. do you use an inline drier valve between the tank and the housing?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
08-06-2008, 06:35 PM | #6 |
no gas at all ... compressed air and electricity only ... esab makes quality replacement parts for most plasma cutters
08-07-2008, 10:41 AM | #7 |
Dirteh Kitteh
One thing to remember is to follow the duty cycle, otherwise your cuts will go all screwy once the power transformer heats up too much.
08-08-2008, 11:22 PM | #8 |
Questionable
i ended up buying this one: http://cm.ebay.com/cm/ck/1065-29392-...m=220264291674
$360 shipped. will let y'all know how it turns out.
08-16-2008, 12:39 AM | #9 | ||
Questionable
i can't figure out how much PSI is required. my 15-20gal compressor kinda sucks, and i'm not sure if it's enough. the Everlast Cut40D i purchased, and this Lotos Cut40D (in the Youtube video) appear to be the same kind of thing - an Esab or Riland clone. here is a Youtube video of some guy using one of the Lotos 40A units: so, since I never said, i wound up buying the Everlast Cut40D $270 + an exorbitant $90 shipping (i'd feel better paying $300 + $60 shipping, seems a little more fair). shipped same day i bought it - service was really good. no communication from the seller (above and beyond giving a tracking number), but does anyone need more than that? nah. it shipped same day, and, seirously that is great service, in my book. unit arrived today, it looks pretty good, was really, really well packed. the logo on the side doesn't look like the auction pictures, but otherwise everything is the same. my only single gripe so far is the manual SUCKS MY BUTT - it's written in really bad "engrish" (chinese translated poorly to english) - and it didn't come with any wiring instructions (you gotta wire on your own plug), all of the units (voltage, pressures, etc.) are values that are printed in metric!! here is an excerpt from the manual which talks about the unit, check out the engrish: Quote:
i need to know how to wire and how much PSI is required, and figure out how to hook up my compressor to this thing (drier valve required?) once that's done, i can test to see if it's DOA, since apparently this happens with a lot of the lesser-known brand plasma cutters on eBay tend to arrive DOA for whatever reason. they claim "free replacement" if the unit is DOA. i have a sneaky suspicion i would be required to pay shipping one-way if the unit is DOA (knowing my luck). if everything works out, it will be kickass. i will definitely report back to you guys, cause i know some of you guys are definitely interested. oh - and the price went up on these things in the last week, apparently.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 08-16-2008 at 12:43 AM. |
08-16-2008, 01:35 AM | #10 |
Questionable
just found out they have a website with my product... http://everlastgenerators.com/produc...ils.php?id=315
and they have a forum dedicated to support of their products... http://weldingweb.com/forumdisplay.php?f=55 unfortunately, support section doesn't have any links to a manual page that i can find. and also noticed that it takes ~65-75PSI range @ 3CFM, roughly. i'm probably only going to be able to cut a 5" line, then hafta stop, wait for the compressor to fill up, rinse, repeat. i also just read that they will send you a DHL label if unit is DOA, and will gladly replace within the first year of ownership, and have done so in several instances, even when it is the user's fault. can't wait to get this thing going ... and might wind up going and buying a better compressor this weekend, better to do it while the wife is on vacation with her mom
08-16-2008, 10:44 AM | #11 |
I run mine at approx. 80-90 psi ... compressor is an 80 gallon but I'm not sure on the CFM
08-16-2008, 11:55 AM | #12 |
Questionable
I'm looking at buying a new compressor today, either way. Probably get a 60gal. Husky 60-gal (oiled) seems to be best bang for buck I can find right now.
Mine is old and tired, and this is a great excuse to get one. I really shouldn't, but ...
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 08-16-2008 at 11:55 AM. |
08-16-2008, 01:15 PM | #13 |
Questionable
i decided to hold off on the compressor. i'll just use the one i got. i need to save the money for other stuff
08-16-2008, 05:22 PM | #14 |
This vertical 80 gallon Ingersol-Rand from Tractor Supply is a helluva deal ... alot of compressor for the money.
08-16-2008, 07:36 PM | #15 |
Questionable
Northern Tool has the 60-gallon 220v compressor for $599 shipped, if i remember right. someone posted about it in the auto body forum.
i'm tempted, but i only wired one 220v outlet in my garage, with a NEMA50p plug for the welder...i don't feel like wiring another 220v outlet! but yeah. i would rather buy the IR 60gal then the Husky 60gal, if it's only ~$80 more. i would rather have an oiled unit than oil-free also.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 08-16-2008 at 07:37 PM. |
08-16-2008, 10:12 PM | #16 |
don't worry so much about the gallon of the tank ... you're money is going towards the CFM ...
08-19-2008, 11:53 AM | #17 | |
and a few others
When shopping, make sure it's single phase 220/240 for home current.
08-19-2008, 10:47 PM | #18 |
Just like to part out trucks!!
Shifty, GREAT thread, I've been thinking on one of these. I just bought accetelyne and oxygen for my big torch and also some for my small tote torch and it was $160, wow I'm tired of that. I have a compressor like Shane showed you, its a good one. Great thread again!!! Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
08-20-2008, 03:39 PM | #19 |
MOVE OVER
So have you used it yet?? I'm curious as well
No matter where you are..... There you are... Buckaroo Banzi |
08-20-2008, 11:22 PM | #20 |
Questionable
i still haven't gotten a manual yet i better call this guy and ask him wtf is up. he obviously isn't responding to email.
08-27-2008, 12:48 PM | #21 | |
PITbut
You cant seem to wire it? Post up pics of what needs to be wired. Shouldnt be any harder then wiring a compressor.... |
08-27-2008, 02:55 PM | #22 |
I have that Hobart model.
It sorta sucks. If i had to buy another one i would spend more money.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
08-27-2008, 03:01 PM | #23 |
PITbut
09-06-2008, 04:14 PM | #24 |
and a few others
shifty, ya makin' any progress, buddy?
09-08-2008, 11:42 PM | #25 |
Questionable
nope. called on thursday, still no call back. will try to call again tomorrow. so far, Everlast gets a ZERO in the customer service department. I just want a legible manual, and clearlly haven't been able to get one.
