Old 08-06-2008, 12:11 AM   #1
Hoffman65burb
Hoffman65burb's Avatar
rear axle
Hey everyone,
I was just wondering if a 12 bolt 72 chevy c10 5 lug axle would fit in my 65 burb, its a 6 lug i think its a 12 bolt also.
Hoffman65burb is offline   Reply With Quote
Old 08-06-2008, 12:39 AM   #2
joe231
joe231's Avatar
Re: rear axle
should bolt right in
CHEVY ONLY
Old 08-06-2008, 01:48 AM   #3
64c20crewcab
64c20crewcab's Avatar
Re: rear axle
Only differance may be the pan hard bar/track arm lenth. The mount on the diff housing may be different between 65 vs 72.
I came across this issue when using a 67 C10 rearend on my last 64 C10.
Good luck!
edit:
The understanding is that the 63-64 and 65-72 trackarm are different in length.
So you actually may be OK if both rigs are 1/2 tons.
Good luck!
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline   Reply With Quote
